Post by mak595 on Apr 12, 2022 10:19:03 GMT 1
Guys, where do the 2 cable guides bolt to on the top yoke plz? I've got the larger of the 2, which I assume is for the clutch cable, does that mount on the bar clamp?
Post by JonW on Apr 12, 2022 10:32:20 GMT 1
Have a god with the search function, I say that as there are a couple of really good photos people have uploaded for this.
Post by mak595 on Apr 12, 2022 10:39:53 GMT 1
Have a god with the search function, I say that as there are a couple of really good photos people have uploaded for this. Found them thanks, I tried the search before but I put wiring clips so nothing came up. I'm a numpty 🤣🤣
Post by shaunthe2nd on Apr 12, 2022 13:38:28 GMT 1
Your clocks look to be mounted wrong, should be underside of yolk. Worth changing before you fit those clips.
Post by JonW on Apr 12, 2022 13:40:28 GMT 1
Your clocks look to be mounted wrong, should be underside of yolk. Worth changing before you fit those clips. Ahh yes, I hadnt noticed that, but yes defo incorrectly fitted.
Post by mak595 on Apr 14, 2022 4:31:16 GMT 1
Your clocks look to be mounted wrong, should be underside of yolk. Worth changing before you fit those clips. Thanks, well spotted 👍
