mk1rob
Post by mk1rob on Jan 13, 2010 20:07:07 GMT 1
iv just striped down my engine from my mk 125lc project ant the piston has been cut down / shortened the holes that should be on the piston wall are gone. what i want to know is why this has been done? what affects it will have? and will it make any kind of difference thanks rob
Post by proam350 on Jan 13, 2010 20:36:33 GMT 1
lot of people used to do it but in my thinking waste of time just get more piston rock in bore and less crankcase pressure for next to no power gains
mk1rob
Post by mk1rob on Jan 13, 2010 22:29:28 GMT 1
yeah i agree iv never seen it before lol i think i will order a new 1 instead of putting this 1 back in. also the barrel has had the ports altered iam guessing for the piston would it affect it by putting a normal 1 back in?
Post by streamline350 on Jan 13, 2010 22:40:38 GMT 1
hi rob defo change the piston post up pic of port work but it wont bother it putting new piston in fella. what oversize you on as have a few piston kits also do alot of tuning so post up pic of cylinder then can see whos been in there if its a good job or not?
mk1rob
Post by mk1rob on Jan 13, 2010 22:44:53 GMT 1
will get some pics up asap
mk1rob
Post by mk1rob on Jan 15, 2010 11:49:47 GMT 1
Post by Norbo on Jan 15, 2010 18:21:37 GMT 1
It was done on some proddy 250's asw ell
Post by streamline350 on Jan 15, 2010 21:10:48 GMT 1
thats a YZ125 PISTON DONT LIKE THE LOOK OF THAT PORTING MATE DONT LOOK TWO GOOD TO ME FELLA....
Post by streamline350 on Jan 15, 2010 21:13:35 GMT 1
JUST HAD A LOOK AT YER PIPE LOOKS ABIT LIKE A NIKON BUT NOT 100% ON THAT MATE
Post by proam350 on Jan 15, 2010 21:18:45 GMT 1
hi rob i think streamlines right that looks like a yz piston to me aswell not sure about wot make pipe it is but think by look of it should be a topend screamer lol..
mk1rob
Post by mk1rob on Jan 15, 2010 21:34:35 GMT 1
well its going to get a new top end definitely the bike has obviously bin played about with to much with some 1 who didn't have a clue wonder what i will find next lol
Post by johnlc on Jan 21, 2010 1:45:46 GMT 1
Think i have seen that porting somewhere before on the other forum didnt think much of it then either .What was the airfilter connected with
mk1rob
Post by mk1rob on Jan 21, 2010 19:05:44 GMT 1
lol it had no air box on it just a bit of fine mesh over the carb
mk1rob
Post by mk1rob on Jan 22, 2010 14:29:41 GMT 1
some one has kindly offered me a top end which i will put on
Post by racerd on Feb 5, 2010 17:21:04 GMT 1
yz piston has 1 piston ring but in the photo the piston has two rings so this a tzr piston kit i use a tzr piston kit in my ypvs barrel
Post by racerd on Feb 5, 2010 17:34:07 GMT 1
below on the right a lc 2.00mm over size piston and on the left a tzr piston below on the right a tzr piston and on the left a yz125h piston below on the right a lc piston in the middle a tzr piston and on the left a yz125h piston all these piston fit straight onto a lc connecting rod (con rod) also got more photo's if needed a few more photo's of above
Post by racerd on Feb 5, 2010 18:04:37 GMT 1
Post by racerd on Feb 5, 2010 18:35:26 GMT 1
