Post by simonlc on Feb 20, 2022 22:20:15 GMT 1
Seems that this is not available anywhere now. It’s the metal shim plate that goes between the sliding caliper and mounting .Anybody know if it is available anywhere?
Post by 29davyt on Feb 20, 2022 23:14:42 GMT 1
Might be worth asking Norbo, I know he does the pad anti rattle shims.
Post by JonW on Feb 21, 2022 2:46:54 GMT 1
never available as a seperate part... if youre asking about an LC?
Post by 4l04ever on Feb 21, 2022 15:05:24 GMT 1
Nick Chambers has these in the pipeline. Not sure when they will be available.
Post by steve63 on Feb 21, 2022 19:36:30 GMT 1
From memory doesn't the manual show a shim under the stainless plates with the return edges? I know mine didn't have anything under that plate.
By shim are we talking about the two parts with the small edges on or something under them?
Post by oldelsieboy on Feb 21, 2022 21:11:33 GMT 1
Post by simonlc on Feb 21, 2022 22:35:41 GMT 1
That’s the ones 9 and 12. No longer available. ☹️
Post by oldelsieboy on Feb 21, 2022 23:04:01 GMT 1
That’s the ones 9 and 12. No longer available. ☹️ If you are desperate and have to have OEM parts, Google the part numbers, there are usually a few available on eBay in the states, listed with exorbitant prices and even crazier shipping. OEB
Post by JonW on Feb 21, 2022 23:09:18 GMT 1
wow good spot Nigel! id never noticed them in the 250 parts book, the 350 doesnt show them at all. Is that and early/late thing? we dont have that here it seems. Not sure how we work out the other side, but they must exist id have thought. something else must have used these calipers....
Post by oldelsieboy on Feb 23, 2022 14:20:50 GMT 1
wow good spot Nigel! id never noticed them in the 250 parts book, the 350 doesnt show them at all. Is that and early/late thing? we dont have that here it seems. Not sure how we work out the other side, but they must exist id have thought. something else must have used these calipers.... Part number for the other side is 4L0-25913-01 OEB
Post by ianlcsince89 on Feb 20, 2023 21:55:11 GMT 1
Hi All, Have just joined your Forum. LC owner since 1989. I do have some background info on the 4L0 brake calipers. I'll try to post the info if someone can tell me how to attach a Word or .pdf document to a post!
Post by crogthomas on Feb 21, 2023 11:42:32 GMT 1
What do these shims actually do? Are they a shim, spring or simply a cover to keep grit out?
Post by 4l04ever on Feb 21, 2023 12:08:54 GMT 1
Hi All, Have just joined your Forum. LC owner since 1989. I do have some background info on the 4L0 brake calipers. I'll try to post the info if someone can tell me how to attach a Word or .pdf document to a post! If you send the info to Xavier to put on his website. RD350LC.NET. You can then put a link in here.
Post by ianlcsince89 on Feb 21, 2023 13:02:48 GMT 1
Okay thanks. I put the caliper info in a new thread last night "RD350LC 4L0 Brake Caliper Info".
Post by JonW on Feb 22, 2023 3:02:03 GMT 1
connect this and hat thread using links from one to the other.
Post by ianlcsince89 on Feb 26, 2023 17:30:20 GMT 1
chuggy
Post by chuggy on Sept 11, 2023 22:23:13 GMT 1
I had the same issue: missing shim ...just cut a 0.5mm piece of shim to the right ship and installed... perfect... clunk has disappeared and caliper feels solid £2 for a big sheet from ebay
