Post by simonlc on Feb 13, 2022 19:06:18 GMT 1
Ok so I know blue spot R1/R6 calipers are a good upgrade for keeping standard discs but a few questions. which year models or are they all the same? I also here other Yamaha ones will fit NK brackets and are cheaper. Also do you have to use master cylinder or can you keep original cylinder?
Post by billbott on Feb 14, 2022 10:33:10 GMT 1
I think that the later types, fitted to fazers onwards look the best. The earlier ones (Thunderace etc) have an external pipe at the bottom. As far as I know, they all fit the same. How much do you want to pay – I have a set of blue spots in the ‘for sale’ section. I used a master cylinder off a 600 fazer, mainly because the one on my Lc needed a rebuild anyway but I believe the Lc ones work ok?
Post by botty on Feb 14, 2022 11:17:41 GMT 1
I think the later gold / silver spots have stainless steel pistons whereas the blue don’t.
Post by cb250g5 on Feb 14, 2022 12:43:28 GMT 1
I think the later gold / silver spots have stainless steel pistons whereas the blue don’t. Blue - mild steel & often rusty pistons. Silver - Reputed to be stainless, I had one on my TDR, was definitely mild steel and rusty. The stainless replacements for blue spots fit fine. Gold - Aluminium, and very thick walled. I have one on my valve. A nice solution to the rusty piston problem.
Post by botty on Feb 14, 2022 14:18:26 GMT 1
I think the later gold / silver spots have stainless steel pistons whereas the blue don’t. Blue - mild steel & often rusty pistons. Silver - Reputed to be stainless, I had one on my TDR, was definitely mild steel and rusty. The stainless replacements for blue spots fit fine. Gold - Aluminium, and very thick walled. I have one on my valve. A nice solution to the rusty piston problem. Every day is a school day 👍
Post by simonlc on Feb 14, 2022 22:51:21 GMT 1
Well ya lives and learns every day 👍
mmikee
Post by mmikee on Feb 26, 2022 10:38:27 GMT 1
This is something I’m thinking about. Where can I get the adapter bracket?
Post by stusco on Feb 26, 2022 17:06:35 GMT 1
Post by 84rzrider on Feb 28, 2022 7:49:51 GMT 1
With the original master cylinder and R1 blue spot calipers it felt wooden to me. I sourced a good used R1 master cylinder with reservoir off eBay for $50.The brake feel is perfect, and it stops good now.
mmikee
Post by mmikee on Mar 1, 2022 15:30:05 GMT 1
They’re not cheap, any alternatives? Got some gold spots coming😁
Post by stusco on Mar 1, 2022 16:10:39 GMT 1
Post by cb250g5 on Mar 1, 2022 18:12:04 GMT 1
I'm using a TDR master, but then again I only have 1 disk. 320mm, it's a big one & more than enough for 1 finger stopping.
mmikee
Post by mmikee on Mar 2, 2022 13:45:58 GMT 1
Which bolts did you use for calliper to adapter?
Post by stusco on Mar 2, 2022 15:44:13 GMT 1
They were titanium from a Ducati off ebay
