Post by paulperth on Nov 19, 2021 11:15:00 GMT 1
Is it possible to fit Norbos Banshee coils to a RD400D fitted with a Newtronics Electronic ignition?
If yes does anyone have a wiring diagram or can explain?
Thanks
Paul
Post by reedpete on Nov 20, 2021 13:13:43 GMT 1
No…you cannot mix use of cdi coils with points systems or their ‘transistorised’ upgrades.
Post by paulperth on Nov 20, 2021 13:33:53 GMT 1
Thank you for confirming Paul No…you cannot mix use of cdi coils with points systems or their ‘transistorised’ upgrades.
Post by LC_BOTT on Nov 21, 2021 9:04:37 GMT 1
I have no idea on aircooled BTW, but Isn't a coil the same whether it's an AC or LC YPVS etc, one LT pulse fires both cylinders/wasted spark etc. So if 'Banshee' coils are no good, couldn't you fit a Dynatek?
Post by gazzatt2 on Nov 21, 2021 21:32:52 GMT 1
the points A/C only fire once per cycle no wasted spark
Post by reedpete on Nov 23, 2021 12:24:04 GMT 1
Also wasted spark aside, the LT voltage on points coil is 6v,12v etc whatever the battery voltage, with cdi (capacitor discharge ignition) the LT voltage, ie the capacitor voltage is 100+V, so totally different coil winding rations and impedance are required.
Post by chrisg on Nov 30, 2021 12:26:28 GMT 1
Also wasted spark aside, the LT voltage on points coil is 6v,12v etc whatever the battery voltage, with cdi (capacitor discharge ignition) the LT voltage, ie the capacitor voltage is 100+V, so totally different coil winding rations and impedance are required. And thats why we are on this forum. A wealth of knowledge and helpful as well.
