Post by evochris on Dec 30, 2021 17:51:40 GMT 1
Build is going well, spend is around 1k so far including picking up the 2 bandit 400βs for parts, refurbishing parts whilst going along, new bearings etc π
Rob123
Post by Rob123 on Dec 30, 2021 20:22:26 GMT 1
Great work Chris, love the wheel colour π
Post by evochris on Dec 30, 2021 21:43:14 GMT 1
Cheers Rob, amazing the amount of hours that go into them, wheel colour is a homage to the 80 yzrβs was not sure about them initially but now grown on me ππ
Post by evochris on Jan 2, 2022 17:38:51 GMT 1
Post by sidney81 on Jan 3, 2022 9:24:04 GMT 1
Looks great ,I like the chain guard nice and simple ππ
Post by yamark on Jan 3, 2022 17:25:29 GMT 1
Great attention to detail, nice to see some new ideas
Great work, Mark
Post by JonW on Jan 4, 2022 13:27:27 GMT 1
I also like the look of that. Whats it off? Could be a good source for other specials?
Post by Mr Kipling on Jan 4, 2022 13:33:48 GMT 1
That looks great, keep up the nice work...
Post by evochris on Jan 6, 2022 12:12:15 GMT 1
I also like the look of that. Whats it off? Could be a good source for other specials? Hi JonW, are you referencing the chain guard? If so it is a modified 2004/05 CBR 125 part, I trimmed it down to a size I liked and leaving 2 mounting lugs ready to fit to the home made brackets. I could have left a bit more meat on the side to hide the top chain run but I like the open look of a nice gold chain I Hope this helps.
Post by evochris on Jan 6, 2022 12:15:05 GMT 1
That looks great, keep up the nice work... Thanks Mr Kipling, more pics to come soon.
Post by evochris on Jan 23, 2022 16:27:47 GMT 1
Post by abar121 on Jan 23, 2022 17:28:02 GMT 1
Looking great.
Post by yamark on Jan 23, 2022 17:29:12 GMT 1
Lovely work, looks spot on to me
Post by andy748 on Jan 23, 2022 18:43:25 GMT 1
I like the black painted insert, well nice. Andy.
Post by evochris on Jan 23, 2022 19:51:12 GMT 1
Cheers fellas,I had it in mind to always paint them but only on when the bike was modified. Came out nice π
Post by dusty350 on Jan 23, 2022 20:06:12 GMT 1
It's ALL about the detail ! Looks really nice Dusty
Post by sidney81 on Jan 24, 2022 12:05:18 GMT 1
Looking forward to seeing this finished!! No rush though π
Post by evochris on Jan 28, 2022 16:34:53 GMT 1
Post by sidney81 on Jan 28, 2022 17:16:31 GMT 1
Thats really cool π
Post by arrdy350 on Jan 28, 2022 17:56:12 GMT 1
I like the hangers and the wheels look greatπ Looking forward to seeing it done π
Post by dusty350 on Jan 28, 2022 23:03:17 GMT 1
I agree, wheel colour looks awesome Dusty
Post by evochris on Feb 14, 2022 12:36:55 GMT 1
Hi All, Small update, Stripped and cleaned carbs and put in 195 jets, EBC fibre reads and fitted new powervalve collar (in between cylinder heads). The old collar had worn to the point where the right valve hardly moved, now all good and set up using the finger up the port method, TBH the hole still aligned on the PV pulley. Fitted the pipes. Hopefully next weekend will be fire up and balancing the carbs. Currently making some spigot tubes to go into the balance holes on the inlet rubbers so I can attached the carbtune kit. RD pipe by chris tring, on Flickr rd pipe 3 by chris tring, on Flickr rd pipe 2 by chris tring, on Flickr
Post by Tobyjugs on Feb 14, 2022 15:19:55 GMT 1
I balanced a set of carbs once using the two holes from the balance tube. It worked well but when I reffited the balance tube and started it idle was over 2000 rpm. Just a heads up.
Post by evochris on Feb 14, 2022 15:46:48 GMT 1
Interesting, do you think the balance tube works to offset the carbs flaws when connect together? I was sort of hoping the isolation from each other would help to balance them and the engine. My method was to slacken the throttle cables right off, adjust the tick over screws until the carbtune showed both identical. Then take all the slack out of the top throttle cable adjuster until its around 2k rpm, then adjust the individual carb cable until again the carbtune is reading the same for both side, then slacken the top cable off until a couple of mm slack is felt hoping it sits back to the tick over speed.......does this method seem any good or is there a better method?
Post by jessy03 on Feb 14, 2022 15:59:03 GMT 1
Iβve used these to balance my carbs, seem to work pretty good. You can get the adapter/spigots off eBay.
Post by evochris on Feb 14, 2022 16:05:19 GMT 1
So you use the balance tube ports with success? I have the carbtune column gauge set that seem to work well on all the 4 stroke 4s I have.
Post by jessy03 on Feb 14, 2022 16:08:54 GMT 1
I set up some pwks on my powervalve with them, seemed to work fine. Jess
Post by jessy03 on Feb 14, 2022 16:17:36 GMT 1
I got the idea off this guy, I think if it was just std carbs then I would just use a drill bit and the windows.
Post by abar121 on Feb 14, 2022 17:08:12 GMT 1
Great. Any idea what size barbed spigots you used?
Think I'll have a go at this with my pwks.
Post by 17again on Feb 14, 2022 17:21:14 GMT 1
conversion is looking good, can't wait to see it finished
