Post by rudy on Sept 26, 2021 18:13:19 GMT 1
Is there anyone who knows the difference between the 1988 4° gear gear (29L-17241-01) and the 1985 4° gear gearbox gear (4LO-17241-01?? At first glance they are the same, then why the other numbering??? Other gears have the same number in the 1988 and 1985 versions.
Post by brigitte on Sept 27, 2021 17:49:45 GMT 1
I would check if the corresponding gear on the other shaft is the same in '85 and '88. When this didn't change, I would try to use it.
Post by midlifecrisisrd on Sept 27, 2021 17:55:13 GMT 1
That's weird
Never thought any 4l0 parts were used in a ypvs gearbox or that the 85 was different
Can't quite remember but either 3/4 or 4/5 input gear is joined so you'd think changing one of the output gears would mean it was the same size 🤔
Post by midlifecrisisrd on Sept 27, 2021 17:56:23 GMT 1
It can only be a revision but the same number of teeth
Post by 4l04ever on Oct 5, 2021 22:01:35 GMT 1
