Post by buck1963 on Oct 1, 2021 21:47:20 GMT 1
Make sure you've got correct flywheel to stator. V similar symptoms to yours , took carbs off so many times, changed cdi, rectifier, new reeds, gaskets. Would start when cold , there after wouldn't fire. Put correct flywheel on and starts first kick, hot or cold I also changed coils , leads plugs ..it drove me mad . When it started it ran ok but turn it off it would not kick over again. Thanks for the input,its definitely better since I fitted the 25 pilots,revs are still hanging very slightly so going to try some 27.5 pilots
