Post by buck1963 on Sept 25, 2021 17:17:33 GMT 1
Hiya folks,I've got a 350 ypvs 31k motor and its giving me a headache,standard carbs and bores with muttsnuts midrange pipes,pilots are 22.5 ,bike will only start from cold with choke on and a little bit of throttle! Ticks over nice once warmed up and the revs hang a bit when I blip the throttle ,once the motors hot it won't start ,won't even fire,any advice/pointers? Thanks
Post by midlifecrisisrd on Sept 25, 2021 18:16:54 GMT 1
Is it a 29k50 cdi?
Famous for dying after the unit has run a little while
Post by buck1963 on Sept 25, 2021 18:59:42 GMT 1
Is it a 29k50 cdi? Famous for dying after the unit has run a little while Steve Thanks for the reply Steve,I've got a zeel fitted
Post by gazzatt2 on Sept 25, 2021 20:01:08 GMT 1
have you checked to see if you have a spark when hot ? has this just started ? have you done any work recently to the bike ? what petrol you using and how old is it ?
Post by buck1963 on Sept 25, 2021 20:22:12 GMT 1
have you checked to see if you have a spark when hot ? has this just started ? have you done any work recently to the bike ? what petrol you using and how old is it ? Thanks for the reply,bikes got a great spark when hot,its not cutting out,im turning the ignition off,petrol is super unleaded from BP,its a bike I've been working on for a while now,I've tried 2 different sets of carbs,both exactly the same because of the tank position im running a low psi fuel pump and a regulator thats producing 1.5psi at the carbs
Post by lc350pete on Sept 25, 2021 22:33:03 GMT 1
Is it worth trying to see what itβs like without the tank just connect up fuel pipe to a bottle of some sort , to eliminate any problem with fuel delivery from the pump setup?
Post by buck1963 on Sept 25, 2021 23:05:38 GMT 1
Is it worth trying to see what itβs like without the tank just connect up fuel pipe to a bottle of some sort , to eliminate any problem with fuel delivery from the pump setup? Thanks for the reply,il try that tomorrow night
Post by lc350pete on Sept 26, 2021 8:43:41 GMT 1
Is it worth trying to see what itβs like without the tank just connect up fuel pipe to a bottle of some sort , to eliminate any problem with fuel delivery from the pump setup? Thanks for the reply,il try that tomorrow night No worries it probably isnβt the petrol feed but itβs easy to eliminate it π
Post by rigga on Sept 26, 2021 10:54:56 GMT 1
Try next size up in pilots .....had a mx bike years ago exactly the same, bit of a bugger not starting after falling off in a race, was advised to fit next size pilot jet, and it was fine after that.
Post by buck1963 on Sept 26, 2021 18:40:10 GMT 1
Try next size up in pilots .....had a mx bike years ago exactly the same, bit of a bugger not starting after falling off in a race, was advised to fit next size pilot jet, and it was fine after that. Thanks for the input
Post by puddy on Sept 26, 2021 22:26:02 GMT 1
Crank seals ? Puddy
Post by marrcel on Sept 27, 2021 9:44:46 GMT 1
Turn your airscrews to 0,5 open.
Post by buck1963 on Sept 27, 2021 19:18:27 GMT 1
Crank seals ? Puddy I don't think so,runs perfect until I switch it off,ticks over perfect
Post by buck1963 on Sept 27, 2021 19:19:40 GMT 1
Turn your airscrews to 0,5 open. thanks for the suggestion,I've got a set of bigger pilots on the way to try
Post by puddy on Sept 28, 2021 14:07:00 GMT 1
Leaking petrol tap , fuel valves not sealing and flooding ? Puddy:)
Post by buck1963 on Sept 28, 2021 18:24:14 GMT 1
Leaking petrol tap , fuel valves not sealing and flooding ? Puddy:) It looks like petrol could be leaking past the needles/seats causing the motor to flood,will know better when I try to start it again,lashing down outside at the mo!
Post by pigboy on Sept 29, 2021 5:29:58 GMT 1
Had this problem with an electronic ignition before , maybe the cdi or pickup coil failing
Post by rigga on Sept 29, 2021 10:54:33 GMT 1
Leaking petrol tap , fuel valves not sealing and flooding ? Puddy:) It looks like petrol could be leaking past the needles/seats causing the motor to flood,will know better when I try to start it again,lashing down outside at the mo! Be worse when starting from cold I would have thought, more time for the fuel to pass and flood the motor, but it starts from cold ok.
Post by arrow on Sept 29, 2021 11:01:25 GMT 1
Leaking petrol tap , fuel valves not sealing and flooding ? Puddy:) It looks like petrol could be leaking past the needles/seats causing the motor to flood,will know better when I try to start it again,lashing down outside at the mo! I had exactly the same problem on my 250E. Genuine Mikuni carb parts cured it.
Post by buck1963 on Sept 29, 2021 20:51:20 GMT 1
Bit of an update,fitted the 25 pilots and fired it up,still needs a bit of throttle to start,even on full choke,definitely sounds better,let it run for five minutes and turned it off,tried to start it and fired up with a bit of throttle,so I think I'm going in the right direction? Going to check the plugs,im thinking that if the petrol is getting past the needles/seats they will be soaking wet? Thanks for all sugestions/ help so far
Post by marrcel on Sept 29, 2021 22:33:35 GMT 1
How many turns the airscrew out? If its too lean, then its time for a leak testπ
Post by buck1963 on Sept 29, 2021 22:35:29 GMT 1
One and a half turns out
Post by marrcel on Sept 29, 2021 22:41:44 GMT 1
I had 1,5out with 27,5π
Post by rigga on Sept 30, 2021 11:01:58 GMT 1
Yes I'd go 27.5 too.
Post by steve h on Sept 30, 2021 11:21:22 GMT 1
It looks like petrol could be leaking past the needles/seats causing the motor to flood,will know better when I try to start it again,lashing down outside at the mo! I had exactly the same problem on my 250E. Genuine Mikuni carb parts cured it. It did it again Gaz!! And got cured again the same way.
Post by arrow on Sept 30, 2021 12:27:34 GMT 1
I had exactly the same problem on my 250E. Genuine Mikuni carb parts cured it. It did it again Gaz!! And got cured again the same way. Cool. You've had that bike a good while now Steve. Is she mostly good?
Post by steve h on Sept 30, 2021 12:45:45 GMT 1
Fires up in about 2 kicks every couple of weeks or longer. Has Aspen in the tank Course she's good, it was put together by a thoroughly decent chap. buck, have you had the "balls out" of the carbs? If you're taking carbs off, it might be worth while doing it.
Post by buck1963 on Sept 30, 2021 21:04:26 GMT 1
Fires up in about 2 kicks every couple of weeks or longer. Has Aspen in the tank Course she's good, it was put together by a thoroughly decent chap. buck, have you had the "balls out" of the carbs? If you're taking carbs off, it might be worth while doing it. Hiya mate ,yes I've done my balls π thanks for the sugestion
Post by frosty123 on Oct 1, 2021 19:54:18 GMT 1
Fires up in about 2 kicks every couple of weeks or longer. Has Aspen in the tank Course she's good, it was put together by a thoroughly decent chap. buck, have you had the "balls out" of the carbs? If you're taking carbs off, it might be worth while doing it. Hiya mate ,yes I've done my balls π thanks for the sugestion Make sure you've got correct flywheel to stator. V similar symptoms to yours , took carbs off so many times, changed cdi, rectifier, new reeds, gaskets. Would start when cold , there after wouldn't fire. Put correct flywheel on and starts first kick, hot or cold
Post by frosty123 on Oct 1, 2021 19:57:39 GMT 1
Hiya mate ,yes I've done my balls π thanks for the sugestion Make sure you've got correct flywheel to stator. V similar symptoms to yours , took carbs off so many times, changed cdi, rectifier, new reeds, gaskets. Would start when cold , there after wouldn't fire. Put correct flywheel on and starts first kick, hot or cold I also changed coils , leads plugs ..it drove me mad . When it started it ran ok but turn it off it would not kick over again.
