toddo
Post by toddo on Sept 25, 2021 14:52:19 GMT 1
toddo
Post by toddo on Sept 25, 2021 18:10:35 GMT 1
That makes more sense especially with the cable routing.
Thank you again Steve!
Todd
Post by JonW on Sept 26, 2021 2:01:17 GMT 1
The 85 has a different shaped clutch perch, thats why its a different cable to the other ypvs's.
The 51L cable is cheap enough at $18.50 from a dealer in Aus, why buy a copy?
toddo
Post by toddo on Sept 26, 2021 14:09:58 GMT 1
Thanks Jon
I paid $23 from wemoto just before I saw your post! I have found that my oil pump cable only allows for enough adustment for the idle marks to line up with the second markings closest to what would be maximum oil flow. I have checked the oil flow at idle and it seems excessive. I have not found in the manual what the volume should be at a specific RPM. I am not sure if one of the markings is for a Canada/US pollution complience but eirther way I suspect some thing is not quite right. I have pulled my spark plugs off when still hot and have seen what looks like a little steam whisping out the spark plug holes so I am worried I may have a bad head gasket/warped head but both looked good and measured straight before going on. Still things to sought out but hopefully be on the road soon.
Todd
Post by midlifecrisisrd on Sept 27, 2021 8:42:24 GMT 1
Copy throttle cables are sh1te
Oil pump cable will most likely be the wrong length
toddo
Post by toddo on Sept 27, 2021 10:00:11 GMT 1
Thanks Steve1
I remember looking for a genuine one a while back but ccould not seem to find one.
