Post by marrcel on Sept 18, 2021 18:18:56 GMT 1
Just picked up this puppy. Only the pivot axle is missing. The size is 20mm and 31k stock 15 or 17 if I remember. What to use
Post by midlifecrisisrd on Sept 18, 2021 18:30:27 GMT 1
Post by marrcel on Sept 18, 2021 21:15:04 GMT 1
Thx Steve My head is a bit slow from hospital toxic. Left my appendix there.
Just to get this a bit clear. 15mm axle, reducer, 20mm tube. I think that is a solution. I have a couple of needle bearings somewere laying around. Can’t remember the sizes. I will check szr drawings if there are bearings involved.
Post by midlifecrisisrd on Sept 18, 2021 21:20:06 GMT 1
Hopefully you are recovering well 🤕
Most likely it will have the usual roller bearings with a bearing sleeve
Simply fit a length of reducing tube inside the bearing sleeve about 1mm narrower than the bearing sleeve so it is still taking the load onto the frame
Post by marrcel on Sept 19, 2021 9:00:21 GMT 1
It will be a 2022 project. I’ll keep progress posted here. Thx steve
