Post by seang14 on Aug 17, 2021 12:47:34 GMT 1
Hi All, So Building an old 1980 350LC bike up from Scratch! Go to kick over No Spark at Plugs!!! Bike has good harness, All new handle bar electrics, New battery, All lights work! I’ve Changed Coil from Bike that Goes, No Change !!!! Help Please! as desperate to get Bike going before Good Weather disappears!
Cheers Sean G
Post by beardy on Aug 17, 2021 14:05:35 GMT 1
Just for starters if I remember correctly. Disconnect the black/white wire under the seat. That should disable the kill switch. Check your coil has a good earth. And just for information. The charging system has no influence on the ignition system
Post by geoffb on Aug 17, 2021 20:43:38 GMT 1
As above, do the coils have a good earth connection to the frame? I had this issue when fitting new Banshee Coils and fixed it by roughing up the earth connections with wet and dry.
