Post by stusco on Aug 3, 2021 15:50:14 GMT 1
Usually if your careful removing the cable you only have to move the spring out a little and it doesn’t unravel,but yours has so you need to spin the pulley putting tension on the spring and reinsert it
hogie
Post by hogie on Aug 3, 2021 20:02:39 GMT 1
Thanks Stusco. I followed your advice and managed to fish out the spring tab which I found sitting in the hole were the cable nipple should sit, managed to bring back round to itshole and seat it with a couple of small screwdrivers and will make note to self to be more careful on the install!
