Post by liffy16 on Jun 27, 2021 19:12:20 GMT 1
Just put my 350pv pipes on my 250lc and its made quite a difference,engine revs up alot quicker,where as with the standard pipes it just wouldnt rev up to 8 grand!.So is there a difference between the 250 and 350 expansion chambers and which pipe is the best for the 250
Post by Gitram on Jun 27, 2021 19:39:13 GMT 1
is your 250 a German import, some of them have a restrictor and some don't..
standard pipes are slightly different between the 250 and the 350LC, more holes in the plates that the baffles slip through for the 350..
marti
Post by liffy16 on Jun 27, 2021 20:09:24 GMT 1
is your 250 a German import, some of them have a restrictor and some don't.. standard pipes are slightly different between the 250 and the 350LC, more holes in the plates that the baffles slip through for the 350.. marti The bike was built from a basket case,the standard pipes are just that with no restriction,it does have 350 carbs and standard porting
aj5764
Post by aj5764 on Jun 28, 2021 6:55:18 GMT 1
Depends on what you want performance wise ... I put Mutts Nutts mid range on my standard 250 power comes in @ 5k sounds like old skool microns but perform way way better in mid range . Worth a phone call to Dave if you can get hold of him or look on his website for more info Cheers Andy
Post by 4l04ever on Jun 28, 2021 9:13:52 GMT 1
Also, TSA can make one off pipes for optimum performance, but they are not an off the shelf item, so may take a while to get done.
If you are after more power, may be worth getting a 350 conversion or 370 Fahron type big bore.
Post by liffy16 on Jun 28, 2021 9:44:33 GMT 1
Also, TSA can make one off pipes for optimum performance, but they are not an off the shelf item, so may take a while to get done. If you are after more power, may be worth getting a 350 conversion or 370 Fahron type big bore. Was thinking about kennys pipes but i believe hes a bit busy at the moment,may just keep the powervalve gibsons on?
Post by abar121 on Jun 28, 2021 10:29:28 GMT 1
Echo the comments about a 350 or 370 conversion. You also need the carb setup for whichever capacity, intake and exhaust you are using.
Post by Norbo on Jun 28, 2021 11:46:01 GMT 1
I have some lovely mid range pipes on the shelf ready go if any one is looking . and in answer to your question . yes you often fined 250's will run better with 350 pipes weather they are lc or ypvs
Post by liffy16 on Jun 28, 2021 13:40:18 GMT 1
Echo the comments about a 350 or 370 conversion. You also need the carb setup for whichever capacity, intake and exhaust you are using. Already have a 350lc and N1 pv was just looking to make the 250 more fun
ajh
Post by ajh on Jun 28, 2021 16:58:25 GMT 1
I have some lovely mid range pipes on the shelf ready go if any one is looking . and in answer to your question . yes you often fined 250's will run better with 350 pipes weather they are lc or ypvs is it just the crossover Tigas on your website or do you have others too? Im after some Stainless midrange / allround pipes for a 4L0 (not crossover)
Post by Tobyjugs on Jun 28, 2021 17:10:52 GMT 1
Echo the comments about a 350 or 370 conversion. You also need the carb setup for whichever capacity, intake and exhaust you are using. Already have a 350lc and N1 pv was just looking to make the 250 more fun I've got an order in with TSA at the moment, not sure how far he is but you could try and contact him as it might be easier to do the same 250 pipes at the same time if it's for a 4L1.
Post by JonW on Jun 29, 2021 1:06:39 GMT 1
I spoke to Dave about some 250 pipes a while back and the demand was not high and the theory was that the 350 wouldnt really be ideal on a 250.
Also, the ypvs and LC have different pipe needs etc. So I am interested to see some dynos of 250 engines with whatever people fit. Of course within the ypvs there is also 51L vs the other cyls and perhaps the 51L has different needs as well. Always interested in 51L stuff as people know as I have two of those engines.
Post by Norbo on Jun 29, 2021 8:14:18 GMT 1
Already have a 350lc and N1 pv was just looking to make the 250 more fun I've got an order in with TSA at the moment, not sure how far he is but you could try and contact him as it might be easier to do the same 250 pipes at the same time if it's for a 4L1. No i have some dedicated mid range pipes that are not crossover they are listed on the site aswell
Post by midlifecrisisrd on Jun 29, 2021 8:40:09 GMT 1
I spoke to Dave about some 250 pipes a while back and the demand was not high and the theory was that the 350 wouldnt really be ideal on a 250. Also, the ypvs and LC have different pipe needs etc. So I am interested to see some dynos of 250 engines with whatever people fit. Of course within the ypvs there is also 51L vs the other cyls and perhaps the 51L has different needs as well. Always interested in 51L stuff as people know as I have two of those engines. The 250 ypvs pipe issue is a problem. Spoke to someone who had tried different pipes and they went back to the standards as everything else destroyed the midrange. Even standard 350 pipes My 51l standard pipes have just went for black ceramic coating and cans went to Dave Swarbrick to get new alloy ones made as the 250 ypvs motor is rev happy already Steve
Post by liffy16 on Jun 29, 2021 10:27:43 GMT 1
I've got an order in with TSA at the moment, not sure how far he is but you could try and contact him as it might be easier to do the same 250 pipes at the same time if it's for a 4L1. No i have some dedicated mid range pipes that are not crossover they are listed on the site aswell Yes they are on the trick bits page further down from the tyga pipes,they look trick👍
Post by JonW on Jun 29, 2021 13:40:18 GMT 1
I spoke to Dave about some 250 pipes a while back and the demand was not high and the theory was that the 350 wouldnt really be ideal on a 250. Also, the ypvs and LC have different pipe needs etc. So I am interested to see some dynos of 250 engines with whatever people fit. Of course within the ypvs there is also 51L vs the other cyls and perhaps the 51L has different needs as well. Always interested in 51L stuff as people know as I have two of those engines. The 250 ypvs pipe issue is a problem. Spoke to someone who had tried different pipes and they went back to the standards as everything else destroyed the midrange. Even standard 350 pipes My 51l standard pipes have just went for black ceramic coating and cans went to Dave Swarbrick to get new alloy ones made as the 250 ypvs motor is rev happy already Steve Ohh nice, defo interested in this, please do let me know how that goes. I could do with a set or two perhaps... the only option ive seen before was from Japan and consisted of a tube you glued over the old rashed cans :/
Post by midlifecrisisrd on Jun 29, 2021 15:48:09 GMT 1
The 250 ypvs pipe issue is a problem. Spoke to someone who had tried different pipes and they went back to the standards as everything else destroyed the midrange. Even standard 350 pipes My 51l standard pipes have just went for black ceramic coating and cans went to Dave Swarbrick to get new alloy ones made as the 250 ypvs motor is rev happy already Steve Ohh nice, defo interested in this, please do let me know how that goes. I could do with a set or two perhaps... the only option ive seen before was from Japan and consisted of a tube you glued over the old rashed cans :/ I've obviously dealt with Swarbrick a couple of times and he was really helpful so when another forum member said he had made him 51l cans I dropped him an email He said the only info he had kept was the flange pcd so could I send them down which I did last week This is what I was told he made Steve
Post by JonW on Jun 30, 2021 1:26:14 GMT 1
Ohh nice, defo interested in this, please do let me know how that goes. I could do with a set or two perhaps... the only option ive seen before was from Japan and consisted of a tube you glued over the old rashed cans :/ I've obviously dealt with Swarbrick a couple of times and he was really helpful so when another forum member said he had made him 51l cans I dropped him an email He said the only info he had kept was the flange pcd so could I send them down which I did last week This is what I was told he made Steve That looks great mate. Please do keep me posted when you get em back and fitted, I'd love to know what they are like for sound and valve etc.
