Post by headcoats on Jun 18, 2021 8:29:34 GMT 1
I will use Genuine crank seals but what about other seals ?
What are good sources of quality aftermarket ones like output shaft, kickstart,gear change,clutch arm,etc
Then there is the water pump seal !
Post by Robbieben on Jun 18, 2021 8:44:10 GMT 1
Norbo keeps all the seals you need in stock.
Post by dusty350 on Jun 18, 2021 9:12:58 GMT 1
I always use genuine Yamaha for all seals, but each to their own.
Dusty🙂
Post by oldbritguy on Jun 18, 2021 11:33:02 GMT 1
Gen every time. Some pattern seals are very good and some not so good. At least you know what you get with genuine parts. I have learned the hard way, buy cheap , buy twice. Each to their own though. John
Post by JonW on Jun 19, 2021 1:36:20 GMT 1
Ive found the aftermarket ones for the case are fine, but it does depend on the quality i guess.
Post by midlifecrisisrd on Jun 19, 2021 10:22:59 GMT 1
I'd say deffo crank, output shaft and oil pump genuine as these are either critical or need the engine split to change (I know you should be able to change the one behind the sprocket without splitting but I tried it once and the seal split at one endge)
Water pump is up to you. All but once I've used genuine. The non genuine one was SKF so was fine but no idea on life
All the rest are fair game for pattern seals
Post by bare on Jun 19, 2021 18:18:04 GMT 1
Seal quality is Not the place to economise. Too effing hard to replace the things.
