Post by mattlon on Jun 11, 2021 9:28:22 GMT 1
Hi Need some help here please, got a dynatek coil with two spades on it and two wires orange and black, which one goes where on the coil and does one need to go to earth? any photos would be much appreciated. thank you
Post by headcoats on Jun 11, 2021 17:36:50 GMT 1
I can watsap you the sheet if you want but it says BATTERY PLUS (+) IS IDENTIFIED ON THE COIL AS A SMALL BUMP MOLDED NEXT TO IT
Post by Chewie01 on Jun 11, 2021 18:27:17 GMT 1
I've been thinking about getting a Dynatek coil for my F2, so any info or images would be helpful to refer to later. I'm also assuming this is the correct unit to purchase? www.ebay.co.uk/itm/363049568099
Post by mattlon on Jun 15, 2021 13:13:28 GMT 1
Many thanks, couldnt find the bump, but as i understand it now, it can be wired either way.and I still got it wrong!!!
Post by headcoats on Jun 15, 2021 14:04:04 GMT 1
I think it can be wired either way but if wrong the spark won't be as stong
Post by muttsnuts on Jun 23, 2021 22:59:22 GMT 1
if the coil doesn't have a "+" sign next one of the spades, then it normally has a blob of red paint next to one, which denotes "+" (orange wire)
