silva
Post by silva on Jun 24, 2021 10:21:04 GMT 1
Hi Robbie,
Which breather? Need to check on it
silva
Post by silva on Jun 24, 2021 10:23:13 GMT 1
Tq ajh, Im from malaysia. The coolant is not pre mixture. Need to change i guess
Post by Robbieben on Jun 24, 2021 11:11:32 GMT 1
Hi Robbie, Which breather? Need to check on it There should be a breather on the gearbox, right hand side of the top casing below the carburettor.
silva
Post by silva on Jun 24, 2021 12:19:12 GMT 1
Noted Robbie. Gona check in a while.
Post by brigitte on Jun 24, 2021 18:11:26 GMT 1
Hi Robbie, Which breather? Need to check on it There should be a breather on the gearbox, right hand side of the top casing below the carburettor. With a little hose on it going down.
The coolant: Just drain about 400ml and fill up with destilled water or drinkable water. This gives still protection against corrosion. Freezing will be a minor problem in your country.
