Gord
Post by Gord on Jun 3, 2021 2:24:25 GMT 1
I forgot to put the damper spacers in when I put my engine back in the frame. Has anyone else done this? Is it worth going back and putting them in. My old ones are worn so I’d probably order new ones which equals more time.
Post by JonW on Jun 3, 2021 2:52:59 GMT 1
yes, fit it. You need it. Front Left and Rear Right. Its fiddly to add the front one in, but the rear is simpler as its on the plate side. use an spare long bolt to hold the engine where it was (as needed, depends on how you bolted it all in) and create/use some wiggle room, if you can find some lol. Get new ones. FWIW use the banshee version as it has more damping and is cheap enough as its cheaper than the other versions: US$11 each. www.partzilla.com/product/yamaha/2GU-15328-00-00
Gord
Post by Gord on Jun 3, 2021 3:40:27 GMT 1
yes, fit it. You need it. Front Left and Rear Right. Its fiddly to add the front one in, but the rear is simpler as its on the plate side. use an spare long bolt to hold the engine where it was (as needed, depends on how you bolted it all in) and create/use some wiggle room, if you can find some lol. Get new ones. FWIW use the banshee version as it has more damping and is cheap enough as its cheaper than the other versions: US$11 each. www.partzilla.com/product/yamaha/2GU-15328-00-00Thanks for this Jon. So there's not 4 of them and just 2?
Post by JonW on Jun 3, 2021 6:17:46 GMT 1
FL and RR, 2 only.
Post by shaunthe2nd on Jun 3, 2021 8:28:29 GMT 1
Agreed, fit them. 2 off diagonally opposite as above. You can fit without removing the engine.
Post by shaunthe2nd on Jun 3, 2021 8:32:12 GMT 1
Norbo sells them £15 a pair.
Post by rigga on Jun 3, 2021 9:47:04 GMT 1
When I removed my engine due to the cracked case, no dampers were fitted, ordered from Norbo a fresh pair
Didn't feel that vibey without them in.
Post by 4l04ever on Jun 3, 2021 11:06:16 GMT 1
They are supposed to help reduce the twisting of the engine, along with the tie bars. They probably don't affect vibrations.
ajh
Post by ajh on Jun 3, 2021 11:52:14 GMT 1
FWIW my non-tiebar 4L0 came with them missing and after fitting them I was convinced it reduced vibration.
Easy to fit, support the engine with some small wood 'chocs' between frame and engine
Gord
Post by Gord on Jun 12, 2021 21:28:39 GMT 1
yes, fit it. You need it. Front Left and Rear Right. Its fiddly to add the front one in, but the rear is simpler as its on the plate side. use an spare long bolt to hold the engine where it was (as needed, depends on how you bolted it all in) and create/use some wiggle room, if you can find some lol. Get new ones. FWIW use the banshee version as it has more damping and is cheap enough as its cheaper than the other versions: US$11 each. www.partzilla.com/product/yamaha/2GU-15328-00-00Thanks for this Jon. So there's not 4 of them and just 2? Finally received new ones.......Does the rubber side face toward the engine or face outward?
Post by JonW on Jun 14, 2021 2:53:38 GMT 1
They used to say i think ecthed into them? but the rubber to the engine from memory, tho it should be obvious when you put it on the engine.
Gord
Post by Gord on Jun 14, 2021 3:30:35 GMT 1
They used to say i think ecthed into them? but the rubber to the engine from memory, tho it should be obvious when you put it on the engine. They used to say i think ecthed into them? but the rubber to the engine from memory, tho it should be obvious when you put it on the engine. Thanks for this Jon - I looked closely and “down” is etched into (I wouldn’t have noticed it if you hadn’t mentioned it) it so can only fit one way.
