fubars
Post by fubars on May 31, 2021 7:21:15 GMT 1
Post by rigga on May 31, 2021 7:26:44 GMT 1
Several have used this, its a good option for when the shift shaft has worn a groove where the seal normally sits.
Post by chrisg on May 31, 2021 13:27:52 GMT 1
It also supports the shaft, if the engine casing housing is worn. There is also a fix for that, involving drilling and reamering and then oversize bush.
