phantom
I ended up needing a new pair of underwear
Post by phantom on May 20, 2021 15:56:58 GMT 1
anyone tried or have an FZR or Mito rolling chassis with an RD/RZ 250/350 engine attached to it? I was checking some stuff for my hybrid built since most of the engine parts are either arriving late or delayed so I'm just doing little by little of check and puzzle pieces. I'm also looking on changing my RZ250RR original frame to a Mito or an FZR 400/600 series.
The Mito rolling chassis can be sort of thru international sellers if ever I'm lucky enough to find one while the FZR frames can be bought locally.
I might be needing any valuable information that can help me up with this one.
Post by Chewie01 on May 20, 2021 17:50:15 GMT 1
I don't know about the FZR 400 chassis but the Mito has had 350 YPVS engines fitted to it loads of times, I've even seen an engine mounting kit listed on ebay in the past. If you do a search on YouTube for Mito 350 YPVS, then you will see a load of videos of this combination.
Post by midlifecrisisrd on May 20, 2021 18:16:29 GMT 1
As above there is a kit for the Mito
As for the FZR I would worry that as it was made for a 4 cylinder the twin would be lost in there
Post by mike1972 on May 20, 2021 18:50:10 GMT 1
Post by dusty350 on May 20, 2021 19:02:36 GMT 1
Post by dusty350 on May 20, 2021 19:07:55 GMT 1
Post by donkeychomp on May 20, 2021 21:26:35 GMT 1
It's been done lots of times as stated, and a fairly simple thing to do (sorta!). I've wanted to do this myself and the main thing are the engine mounts that can be bought of the 350 Mito site as Dusty listed. The forks need modding too. Unless you go for some other type of fork?
phantom
Post by phantom on May 21, 2021 15:30:12 GMT 1
I don't know about the FZR 400 chassis but the Mito has had 350 YPVS engines fitted to it loads of times, I've even seen an engine mounting kit listed on ebay in the past. If you do a search on YouTube for Mito 350 YPVS, then you will see a load of videos of this combination. I did research about the MITO YPVS hence it fascinated me up with that project but also finding a rolling chassis would be a problem for me since those mito are nowhere or rare to find back to my country and can only be source thru international sellers.
phantom
Post by phantom on May 21, 2021 15:30:31 GMT 1
interesting to see this one thanks!
phantom
Post by phantom on May 21, 2021 15:32:26 GMT 1
It's been done lots of times as stated, and a fairly simple thing to do (sorta!). I've wanted to do this myself and the main thing are the engine mounts that can be bought of the 350 Mito site as Dusty listed. The forks need modding too. Unless you go for some other type of fork? Alex well true further researching I did stated that changing the fork to a better one is the way to go for stopping power mostly folks uses ducati 9xx series for their front forks.
Post by 3tj6 on May 21, 2021 20:12:50 GMT 1
There was a fzr 400 rrsp 3tj with a ypvs 350 engine in it at the cmc clay cross 2 stroke day a couple of years ago 😊
Post by donkeychomp on May 21, 2021 21:37:15 GMT 1
On a similar note I'm doing the opposite. An LC frame with Mito front and rear ends. For me the only issue is locating the rear shock but the FF Brembo single disc will be more than enough to stop the bike!
phantom
Post by phantom on May 23, 2021 0:26:36 GMT 1
There was a fzr 400 rrsp 3tj with a ypvs 350 engine in it at the cmc clay cross 2 stroke day a couple of years ago 😊 is there any photo's of it?? kinda interested on seeing how the owner did it well and how he cover the engine with those fairings
phantom
Post by phantom on May 23, 2021 0:27:09 GMT 1
On a similar note I'm doing the opposite. An LC frame with Mito front and rear ends. For me the only issue is locating the rear shock but the FF Brembo single disc will be more than enough to stop the bike! Alex interesting project changes you are going there, kinda interesting to see once its done
