Nuts
May 18, 2021 20:41:32 GMT 1
Post by donkeychomp on May 18, 2021 20:41:32 GMT 1
Nuts
May 18, 2021 21:43:05 GMT 1
Post by Chewie01 on May 18, 2021 21:43:05 GMT 1
That's not good. Take out for dinner for a while?
Nuts
May 18, 2021 21:47:26 GMT 1
Post by donkeychomp on May 18, 2021 21:47:26 GMT 1
You're right...it's not good! Can't get a replacement door as the oven is obsolete so I need a new one. For now I'm going to 'construct' a front door with tin foil...
Nuts
May 18, 2021 21:51:52 GMT 1
Post by shaunthe2nd on May 18, 2021 21:51:52 GMT 1
I had the same in one of my rentals, happened first time after I paid a company to clean it. Luckily my tenant wasn't stood next to it at the time, hope nobody injured in your case.
Was cheaper to replace than fix, paid £95 for new one (with fan) at one of those returns warehouses, and got a 6 month guarantee.
Nuts
May 18, 2021 21:52:11 GMT 1
via mobile
Post by midlifecrisisrd on May 18, 2021 21:52:11 GMT 1
How on earth did that happen?
Nuts
May 18, 2021 21:56:41 GMT 1
Post by steve h on May 18, 2021 21:56:41 GMT 1
Get down the tip and scrounge around for one off a scrapper....cut to size. Reuse, recycle, save the planet.
If its just an outer door, f*** it and carry on using it, just dont let the dog sniff it whilst your nut roast is in it...
Nuts
May 18, 2021 22:53:31 GMT 1
Post by donkeychomp on May 18, 2021 22:53:31 GMT 1
I'll tell you how it happened. I cooked dinner, ate it then was doing the washing up when KABLAMMO! No humans/cats/dogs or field mice were hurt during this incident.
Steve, there are no scrappers anymore. Well, not here anyway. I could claim on insurance but a new oven is about £200. However it needs wiring into the mains and that means getting someone in to do the job. No way would I attempt this. I'll do a bit of ringing about tomorrow and see what a quote is.
Nuts
May 18, 2021 23:07:06 GMT 1
Post by shaunthe2nd on May 18, 2021 23:07:06 GMT 1
Its as easy to wire as it is to do a plug, just thicker cables. I don't think you need to be an electrician to install these.
Nuts
May 18, 2021 23:16:19 GMT 1
Post by steve h on May 18, 2021 23:16:19 GMT 1
I think if any wiring is done in a kitchen ...it has to be done by an "electrician" nowadays?? Insurance and all that bollix?? You may find a door Alex... You may get lucky.
Post by steve h on May 18, 2021 23:22:25 GMT 1
Nuts
May 19, 2021 2:30:51 GMT 1
Post by JonW on May 19, 2021 2:30:51 GMT 1
Eeek, glad youre ok Alex! Scary stuff. Are none of the UK ovens fitted with a plug these days? I know my Euro made 15 year old oven has one here in Aus as I had to get it out to cut out the top bigger for the large gas hob we had fitted. I simply slid the oven out (couple of screws holding it to the cupboard sides once door is open) and pulled the plug... reassembly is reverse of removal
Nuts
May 19, 2021 7:15:01 GMT 1
Post by dusty350 on May 19, 2021 7:15:01 GMT 1
"School of Spice" is open for take away's mate - best curry in Shepperton ! It's either that or salad !! I will keep an eye out on my travels - people often upgrade when refurbing a kitchen and single ovens are often given away to make room for a new one. Dusty
Nuts
May 19, 2021 8:50:40 GMT 1
via mobile
Post by midlifecrisisrd on May 19, 2021 8:50:40 GMT 1
As Jonw said
Check it's not got a 13a standard plug on it
Most single ovens are like that
Only when you go to doubles or a high powered one is it likely to need hard wired
Usually 4 screws going into the front of the cabinet. Slides straight out
Toughened glass is a fecker when it pops
Post by donkeychomp on May 19, 2021 21:51:54 GMT 1
Thanks lads. The first thing I did was google parts suppliers, including the one Steve suggested. 15 of them had the door...but none available as this oven is over 30 years old! It doesn't have a plug, it's wired into the wall. Cheers for keeping an eye out Dusty, anything that works would be good, though new ones can be had for about £200. The issue is in getting a qualified sparky to come along and fit it. Might have to go through my insurance if all else fails.
One good thing...I wanted to use it tonight so I wrapped the door in foil, and everything worked perfectly, no excess heat coming through. So for now...I can eat lol.
Post by JonW on May 20, 2021 4:26:44 GMT 1
The world has gone nuts... 3 colour coded wires. I blame the millenials. paying a call out for a sparky to switch the power off and swap 3 wires and switch the power back on depresses me, plus it could take weeks to get one. Welcome to the new world.
Nuts
May 20, 2021 11:31:47 GMT 1
Post by steve h on May 20, 2021 11:31:47 GMT 1
Red, yellow, blue, and black (N)..Old phase colours. Now replaced with Euro colours (20yrs ago) Brown, grey, black, and blue (N)
So on pre 2001 ish jobs we have wire containment with 240V on black conductors and other black conductors acting as Neutral..... And 240V on blues and other blues as Neutral.
Everyone thought it was utter madness at the time... yes jonw, it's nuts. And our Institute of Electrical Engineers went along with it....
Jobs wired with old colours will be around a long time......longer than EU influence on colour codes or compliance!
Nuts
May 20, 2021 13:26:32 GMT 1
Post by reedpete on May 20, 2021 13:26:32 GMT 1
The world has gone nuts... 3 colour coded wires. I blame the millenials. paying a call out for a sparky to switch the power off and swap 3 wires and switch the power back on depresses me, plus it could take weeks to get one. Welcome to the new world. Might be the ‘rules’ ...but so is the 70 mph speed limit !.... if it’s community building or tenanted....need to be a bit mindful of requirements...but in your own home.....rules is one thing and confidence to do a job is another.... like you said....an oven is just three wires...
Nuts
May 20, 2021 19:28:35 GMT 1
Post by jon on May 20, 2021 19:28:35 GMT 1
I'll tell you how it happened. I cooked dinner, ate it then was doing the washing up when KABLAMMO! No humans/cats/dogs or field mice were hurt during this incident. Steve, there are no scrappers anymore. Well, not here anyway. I could claim on insurance but a new oven is about £200. However it needs wiring into the mains and that means getting someone in to do the job. No way would I attempt this. I'll do a bit of ringing about tomorrow and see what a quote is. Alex I had one go in exactly the same way. Put it down to hot inside and cold outside. I’ve had about 4 ovens over the last 26 years. All had 32amp cable to attach. The last one was only 13amp. It worried me until I spoke to someone in the know. Jon
Nuts
May 20, 2021 19:31:13 GMT 1
Post by jon on May 20, 2021 19:31:13 GMT 1
Red, yellow, blue, and black (N)..Old phase colours. Now replaced with Euro colours (20yrs ago) Brown, grey, black, and blue (N) So on pre 2001 ish jobs we have wire containment with 240V on black conductors and other black conductors acting as Neutral..... And 240V on blues and other blues as Neutral. Everyone thought it was utter madness at the time... yes jonw, it's nuts. And our Institute of Electrical Engineers went along with it.... Jobs wired with old colours will be around a long time......longer than EU influence on colour codes or compliance! When you say old phase colours, is that 3 phase? Single phase in a house used to be red-live, yellow and green-earth and black-neutral. Jon
Nuts
May 20, 2021 19:43:53 GMT 1
via mobile
Post by midlifecrisisrd on May 20, 2021 19:43:53 GMT 1
Yes
Your house should now be brown for live and blue for neutral
The thing is should the 3 coloured phases not have a section of brown sleeving on them to identify them
Like when a lighting circuit is wired either loop in at the light fitting or junction box you should really sleeve the black switch wire in red sleeving (like what never happens 😂)
Same at a 2 way or intermediate switch with the blue and yellow pass wires ("strappers" for the older sparkies)
Nuts
May 20, 2021 19:47:06 GMT 1
Post by jon on May 20, 2021 19:47:06 GMT 1
Yes X wire Your house should now be brown for live and blue for neutral The thing is should the 3 coloured phases not have a section of brown sleeving on them to identify them Like when a lighting circuit is wired either loop in at the light fitting or junction box you should really sleeve the black switch wire in red sleeving (like what never happens 😂) Same at a 2 way or intermediate switch with the blue and yellow pass wires ("strappers" for the older sparkies) Steve From memory they started using the new colour coding for flex, way before the standard cable was switched over, so it came as no surprise. Jon
Post by midlifecrisisrd on May 20, 2021 19:51:45 GMT 1
Whatever they use now and in the future it will never be worse than either the old conduit V.I.R. cable, the lead sheathed cable or the later TRS sh1te
