Post by noonster on Apr 27, 2021 20:07:35 GMT 1
How do i remove the round pins from the connector block,
had good results with flat spades using a small terminal screw driver on my lc handle bar switches,
Wanting to take them off so i can re sleeve them
Post by steve h on Apr 27, 2021 21:50:48 GMT 1
A round pin extractor, The extractor is slightly bigger than the pin and thin enough to fit between pin and plastic block. Can be fashioned from small tube.. like a ferrule. You may still be able to extract a round pin with very thin sliver of metal. You can buy sets of extractors, but I used to make them up for myself at work.
I rebuilt my 400s switchgear recently, stripped, paint, contacts cleaned, new sleeve, ect.
