fubars
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Post by fubars on Apr 24, 2021 7:36:28 GMT 1
Just wondering what's the most sought after part/parts of the LC are ?
Post by dusty350 on Apr 24, 2021 7:42:11 GMT 1
Anything that is sensibly priced !! ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
fubars
Post by fubars on Apr 24, 2021 7:43:00 GMT 1
Anything that is sensibly priced !! ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Nothing then ๐
jam911
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png) ![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Post by jam911 on Apr 24, 2021 7:43:35 GMT 1
From my small and personal experience/searches so far...
Headlight brackets Seat latches Seats
Post by veg on Apr 24, 2021 7:51:42 GMT 1
Tool trays, coil covers, battery box strap and uncut non EU rear mudguard
Post by liffy16 on Apr 24, 2021 8:08:08 GMT 1
Centre stands,clocks mph or kph,rear grab rails,rear footrests are very rare,that's what I found on my last 250 build ,not so much rare just bloody expensive, not as bad as vintage bmx stuff though ! Now that's just ridiculous ๐
Post by reedpete on Apr 24, 2021 8:49:41 GMT 1
The most sought after part of the LC is its sound and feel...
Many of the hard to find parts are now available as pattern, the main stand is just most recent example. Also many parts still available new from Yamaha, front mudguard for example and others are common between 250 and 350.... the Pattern list now includes, tank, side panels , rear mudguard, horn bracket, horn cover,
So to make a general comment you can deduce the hardest to find parts are outside of this group.
Single most expensive item?.....pair of 4L0 barrels on low bore.
Most expensive in terms of ยฃ/kg ? ....Coil cover/tidy
Most rare?.....alloy fuel cap,
Hardest part to 3D print or soft tool?......number plate bracket
Most desirable intangible item? ...the imprint of a few similar numbers stamped into the frame and engine ๐๐๐
Think thatโs enough headings to make a set of top trump cards ๐...
Post by elsiefan on Apr 24, 2021 13:53:23 GMT 1
The most sought after part of the LC is its sound and feel... Have to agree with this ๐ Just got back from giving mine a shakedown run through the local lanes and can still hear the 'ring ding ding' in my ears!
Post by JonW on Apr 24, 2021 14:19:17 GMT 1
the rarest part is the one you need.
Post by dougw on Apr 25, 2021 9:43:38 GMT 1
Good standard 350 exhausts difficult to get. Plenty of cut up or 250 seem to be about, but as I'm trying to get my previously badly bodged 350 running properly in near standard tune. I don't want to add another unknown! ( settled on 31K ypvs ones for now, as I had some in reasonable nick, and it likes them ,more than the microns, anyway)
Post by andydbexley on Apr 27, 2021 11:24:02 GMT 1
Would love for someone to tell me Iโ wrong but original seats particularly the bases I know itโs possible to get foam and covers but decent bases are firmly in the rocking horse dodo category
Post by chrisg on Apr 27, 2021 12:51:47 GMT 1
Centre stands,clocks mph or kph,rear grab rails,rear footrests are very rare,that's what I found on my last 250 build ,not so much rare just bloody expensive, not as bad as vintage bmx stuff though ! Now that's just ridiculous ๐ 350 cylinders Matching 4L0 Engine cases 350 exhausts 350 01 carbs
Post by midlifecrisisrd on Apr 27, 2021 13:15:58 GMT 1
The bit you need ๐ญ
Post by abar121 on Apr 27, 2021 13:30:14 GMT 1
Master cylinder screws that haven't been attached by Woolworth's my first tool kit.
Post by Chewie01 on Apr 27, 2021 14:18:17 GMT 1
The most sought after part of the LC is its sound and feel... Have to agree with this ๐ Just got back from giving mine a shakedown run through the local lanes and can still hear the 'ring ding ding' in my ears! And it's way better after you ditch the standard pipes.
Post by shaunthe2nd on Apr 27, 2021 14:37:26 GMT 1
Headlight adjuster bracket.
Post by 4l04ever on Apr 27, 2021 16:14:44 GMT 1
Headlight adjuster bracket. Norbo does good replica ones.
Post by headcoats on Apr 27, 2021 16:17:38 GMT 1
Headlight adjuster bracket. Aren't these remade now
Rare parts as mentioned are the ones you need LOL
Number plate holder , clock wiring, side stand,good LC radiator, wiring loom,
Think it's still amazing you can still get new LC switch gear, clock covers, radiator cover,
I guess the radiator and clock covers don't fit anything else , so what is the reasoning at Yamaha about this ?
Post by shaunthe2nd on Apr 27, 2021 17:11:28 GMT 1
Headlight adjuster bracket. Norbo does good replica ones. Good to know, didn't realise that.
Post by bare on Apr 27, 2021 17:42:58 GMT 1
The most sought after part of the LC is its sound and feel... ............... Many of the hard to find parts are now available as pattern, the main stand is just most recent example. Also many parts still available new from Yamaha, front mudguard for example and others are common between 250 and 350.... the Pattern list now includes, tank, side panels , rear mudguard, horn bracket, horn cover, So to make a general comment you can deduce the hardest to find parts are outside of this group. Single most expensive item?.....pair of 4L0 barrels on low bore. Most expensive in terms of ยฃ/kg ? ....Coil cover/tidy Most rare?.....alloy fuel cap, Hardest part to 3D print or soft tool?......number plate bracket Most desirable intangible item? ...the imprint of a few similar numbers stamped into the frame and engine ๐๐๐ Think thatโs enough headings to make a set of top trump cards ๐... Geee lucky me. I have All of those bits, a couple pairs of cyls even .
Post by firmstools on Apr 27, 2021 18:41:08 GMT 1
I have wondered this too!
Post by reedpete on Apr 27, 2021 19:47:33 GMT 1
Bare is right...should qualify , only rare if you donโt have a personal stash ! Iโm sure the folks of this manor could account for a significant quantity of whatโs out there hidden away. But if you are a long term hard core RD nut it goes with the territory!
Post by djp22q on Jul 24, 2024 0:21:59 GMT 1
Who does the rear mudguard
Post by dusty350 on Jul 24, 2024 6:33:13 GMT 1
Norbo
Post by dodgyknees on Jul 24, 2024 8:15:54 GMT 1
Who does the rear mudguard Not in stock waiting for a new mould askeda few days ago I want one too
Post by midlifecrisisrd on Jul 24, 2024 9:11:27 GMT 1
Would love for someone to tell me Iโ wrong but original seats particularly the bases I know itโs possible to get foam and covers but decent bases are firmly in the rocking horse dodo category This may blow your mind but here goes New seat bases are available ๐ฎ Steve
red998
Post by red998 on Jul 24, 2024 9:33:09 GMT 1
A good quality standard exhaust I have found. Not found one yet that's decent and fairly priced.
Post by JonW on Jul 24, 2024 9:37:46 GMT 1
With the recent drop ('bottom has fallen out' Ive seen written) of the LC market... has anyone let the parts sellers know yet?
If they have, from what Ive seen, I dont think they got the memo...
Post by midlifecrisisrd on Jul 24, 2024 10:37:07 GMT 1
With the recent drop ('bottom has fallen out' Ive seen written) of the LC market... has anyone let the parts sellers know yet? If they have, from what Ive seen, I dont think they got the memo... Funny thing there The value of complete bikes has fallen but parts for maintaining or building them has stayed relatively high Yes centre stands are no longer ยฃ300 but still pricey Interestingly my parts guy who had previously said importing complete bikes for breaking was no longer viable has recently bought in and broke bikes for parts ๐ค Steve
Post by bezzer on Jul 24, 2024 18:23:33 GMT 1
Caliper shims appear to be made of Unobtanium if my wanted ad is anything to go by โน๏ธโฆ๐คฃ๐คฃ๐คฃ๐คฃ
