Post by Robbieben on Apr 15, 2021 22:57:39 GMT 1
I'm toying with the idea of a hybrid build rather than restore the 31k I've just bought. Maybe keep the fairing??? K4 GSXR 600 front forks, rear swingarm, wheels, brakes etc into an LC frame, obviously some modifications to make but has anyone used GSXR 600 parts and found major hurdles?
Post by oldbritguy on Apr 16, 2021 17:39:26 GMT 1
Certainly if you have access to engineering services you could make just about anything fit with a bit of fettling.
Look through the resto hybrid builds on here and you will see a myriad of different front/rear ends being skilfully fitted to LC and PV frames. RGV parts are a common choice so GSXR running gear wont be far off the mark I imagine. (He says with a wry grin!!)
Like most though be prepared for some challenges along the way and don't forget the pics as you go
John
Post by midlifecrisisrd on Apr 16, 2021 18:02:52 GMT 1
Post by 4l04ever on Apr 16, 2021 19:51:54 GMT 1
Worth checking the fork lengths, as some are quite a bit shorted than original LC/YPVS forks, which could make the front end look low and make the bike look sloping down to the front. 17" wheels will lower the bike a little too.
Post by marrcel on Apr 16, 2021 22:36:18 GMT 1
It is not difficult to make a good looking hybrid. To get the geometry sorted and the springrate., that is the key to make good laptimes. 🤓
phantom
I ended up needing a new pair of underwear
Post by phantom on Apr 16, 2021 23:39:00 GMT 1
I'm toying with the idea of a hybrid build rather than restore the 31k I've just bought. Maybe keep the fairing??? K4 GSXR 600 front forks, rear swingarm, wheels, brakes etc into an LC frame, obviously some modifications to make but has anyone used GSXR 600 parts and found major hurdles? interesting will follow on this thread to get some good info about front fork set ups
