Post by jon on Apr 11, 2021 10:13:33 GMT 1
Hi all,
Out of interest when fitting a YPVS engine to an LC how much if any do you have to trim off the rear of the generator cover to clear the frame?
Post by jessy03 on Apr 11, 2021 12:34:35 GMT 1
From memory it’s not much may be 10mm or so, or you could fit the LC one Jess
Post by dusty350 on Apr 11, 2021 12:38:08 GMT 1
Yea, I've had to trim a bit off the plastic left side case when fitting the Pv engine in an Lc frame. I always fit Lc side cases now though, so no issues. Dusty
Post by headcoats on Apr 11, 2021 15:25:58 GMT 1
Use an LC cover, it's the law.
Post by midlifecrisisrd on Apr 11, 2021 15:46:35 GMT 1
I'm sure I had one that just had the top edge notched for the frame spar
You have to trim the rear edge for an LC case in a ypvs so assume the ypvs case is smaller there
Post by bare on Apr 12, 2021 16:36:40 GMT 1
LC cover is at least Ali. Whereas the Valvie one is shitty plastic. Good riddance... imo
Post by JonW on May 6, 2021 5:00:52 GMT 1
Use an LC cover, it's the law. 100% this.
Post by chrisg on May 6, 2021 17:41:02 GMT 1
Use an LC cover, it's the law. 100% this. Sorry to hi jack this thread, but would you need to fit a complete PV harness to enable the servo to work or can this be "spliced" into the 4L0 harness? I have looked at this mod for some time.
Post by midlifecrisisrd on May 6, 2021 18:26:34 GMT 1
Sorry to hi jack this thread, but would you need to fit a complete PV harness to enable the servo to work or can this be "spliced" into the 4L0 harness? I have looked at this mod for some time. If you are using PV cdi and pv controller The only real extra bit is a 12v switched power supply and the 5 servo wires so a piece of pish to make up If using a zeel or Iggy then the servo connects to them PV stator charging and neutral plug goes straight into an LC loom Steve
Post by jon on May 7, 2021 19:41:17 GMT 1
Use an LC cover, it's the law. 100% this. I’m afraid that’s not going to happen. I have 2 billet Legend YPVS generator covers that I love and intend to use. Far more trick IMO than simply bolting on an LC one. I cannot comprehend how much waste there was from the billet, which makes them all the more exclusive in my eyes. Jon
Post by bare on May 16, 2021 0:54:54 GMT 1
Your $$$ your Phantasy. Clearly you've answered your own question :-)
Post by beardy on May 16, 2021 8:20:41 GMT 1
Your $$$ your Phantasy. Clearly you've answered your own question :-) And what was the question?? 😂
Post by jon on May 17, 2021 21:38:52 GMT 1
Your $$$ your Phantasy. Clearly you've answered your own question :-) And what was the question?? 😂 Struggling to work out what bare means too, but thats not that unusual with him? The question was do I need to trim any off? Irrelevant if plastic or aluminium IMO? Only difference is one is already anodised black, and one is for an LC frame and the other for a YPVS. I’d rather use the black one on the YPVS if it needs trimming. Jon
Post by mintyfresh on May 17, 2021 22:22:31 GMT 1
Big hammer!!!
Post by steve63 on May 25, 2021 13:03:52 GMT 1
I fitted the YPVS plastic one. It's lighter than the LC aluminium one and the YPVS doesn't need the clutch cable fitting so why use that cover?
It takes about five minutes tops to remove the bit of plastic that catches the frame. That's how I remember it from 1987 when I did my conversion.
FYI, I fitted the engine, wiring harness, switch gear and clocks from an F1. Job done!
Post by steve63 on May 25, 2021 13:04:56 GMT 1
And what was the question?? 😂 Struggling to work out what bare means too, but thats not that unusual with him? The question was do I need to trim any off? Irrelevant if plastic or aluminium IMO? Only difference is one is already anodised black, and one is for an LC frame and the other for a YPVS. I’d rather use the black one on the YPVS if it needs trimming. Jon I think it translates as: Your money, do as you like! Maybe fantasy is spelt with a PH over there?
