Post by midlifecrisisrd on Apr 3, 2021 18:15:06 GMT 1
As title I need someone to check a measurement as I have done in the pics I think the bracket on the new LC hybrid frame looks off but what do I know, this is only the second one I've done 😬 Basically I need the correct measurement from the inside of the RH frame rail at the reinforced bit to the inside edge of the point on the bracket This frame is just under 280mm Thanks in advance Steve
Rob123
Post by Rob123 on Apr 3, 2021 20:20:55 GMT 1
Hi Steve, Just been and measured mine and its exactly 275mm from the reinforced part to the inside edge of bracket point. Your not far off although I can imagine a few mm will make a fair bit of difference at the other end.
Post by midlifecrisisrd on Apr 3, 2021 20:41:26 GMT 1
Hi Steve, Just been and measured mine and its exactly 275mm from the reinforced part to the inside edge of bracket point. Your not far off although I can imagine a few mm will make a fair bit of difference at the other end. Cheers for that 😀 That's a lot nearer than I thought I'm not sure whether to cut it off and get it rewelded Bike will have jacked out footplates to clear the swing arm so may help with pipe clearance 🤔 Steve
Rob123
Post by Rob123 on Apr 3, 2021 20:56:19 GMT 1
I'd be more than happy with that for a guess 😂👍
