Post by veg on Apr 3, 2021 9:31:52 GMT 1
Anyone fitted a pro am fairing? I bought a new one including the bracket and cannot get the b*****d thing to fit tried everything. Were the original ones as bad?
Post by oldelsieboy on Apr 3, 2021 9:51:18 GMT 1
Anyone fitted a pro am fairing? I bought a new one including the bracket and cannot get the b*****d thing to fit tried everything. Were the original ones as bad? Original Brealey Smith set fitted without any issues. OEB
Post by veg on Apr 3, 2021 11:27:48 GMT 1
Thanks Nigel I know the original fitted ok it’s the bracket that is completely out of kilter and can’t be persuaded to fit I have both the kit instructions and the original ones it’s just too far away. 👍
Post by Tobyjugs on Apr 3, 2021 14:12:45 GMT 1
Hammer Time
Post by steve h on Apr 3, 2021 16:02:56 GMT 1
Post by veg on Apr 3, 2021 16:06:31 GMT 1
The problem is that it is so completely out of alignment even persuasion with a lump hammer may not do the trick. I’ll look at what alternatives there are.
Post by steve h on Apr 3, 2021 16:14:48 GMT 1
If it is a Smith offering, they are very flexible, and bend quite a lot till they break....
Post by reedpete on Apr 3, 2021 16:46:24 GMT 1
Got a vague recollection about someone else struggling to get a pattern ProAm bracket to fit...just can’t pull all details . Presume yours is second hand tim ?
Post by veg on Apr 3, 2021 17:47:02 GMT 1
No Pete I bought from Norbo new he did say it might be a challenge to fit, I’m wondering about grinding off the mounts and using so P clips I’ll see if that’ll work?
Post by tipfinchy on Apr 3, 2021 17:49:20 GMT 1
Post by veg on Apr 3, 2021 18:05:45 GMT 1
Thanks, I’ve looked at what’s available but I’m Pretty certain they are all made by the same company tbh, so I think I will fabricate something myself as even if I found an original brearley smith one it’ll probably not then fit the fairing. The one I have can’t actually fit onto the bike and then it also doesn’t fit the fairing.
Post by carioca656 on Apr 3, 2021 20:54:02 GMT 1
I've just fitted one myself there not the best fit just a bit of pushing and squeezing and it fitted not too bad
Adie
Post by lcmarky on Apr 4, 2021 18:34:55 GMT 1
Mead Speed are a joke. Utterly rubbish brackets. I contacted them and said what on earth have you sent to be told it should just bolt on - oh covered in manufacturing fibreglass debris too.
You will need to re-engineer it if it’s a mead speed as they clearly haven’t got a clue or a quality control department.
Post by veg on Apr 4, 2021 19:00:56 GMT 1
I think the quality must be varied as some say a little bit of bending it fits and others like mine are impossible.
