Post by liffy16 on Mar 28, 2021 13:04:30 GMT 1
Went for quick spin on LC and noticed headlight not working?did obvious stuff checked bulb switchgear the connectors under the tank.put meter across fuses and it was the lower connector/wire.There are remakes fuse boxes on eBay anyone tried them ?
Post by skydemon on Mar 28, 2021 14:43:37 GMT 1
Where is the connector?? Do you have a photo??
Post by liffy16 on Mar 28, 2021 15:02:10 GMT 1
Where is the connector?? Do you have a photo?? Sorry can't do photos, it is the bottom fuse holder clip
Post by chrisg on Mar 28, 2021 15:32:46 GMT 1
Post by liffy16 on Mar 28, 2021 15:40:20 GMT 1
Dont think it's a shambits, doesn't come with separate plug
Post by veg on Mar 28, 2021 15:56:08 GMT 1
I’d take it out clean it and recrimp or solder it if possible?
Post by chrisg on Mar 28, 2021 16:49:45 GMT 1
Dont think it's a shambits, doesn't come with separate plug No the standard one is part of the harness. Shamits idea is to cut the old one and add fit the connector block and new fuse carrier. My suggestion was to hard wire it in.
