Post by mattlon on Mar 24, 2021 14:58:22 GMT 1
Hi After a bit more help, sorted the tyres and exhausts are on the way but now having sparking issues. Went to start and the spark has disappeared, fiddled around with all the wires and it reappeared. Thinking coil? Looked on ebay and rdlc crazy and can't see anything? don't want to go secondhand, seen some bright coloured ones? What's the general opinion? Thanks in advance
Matt
ajh
Post by ajh on Mar 24, 2021 17:58:21 GMT 1
if you 'fiddled around with all the wires' it might be a lot cheaper to check you dont just have a dodgy connection or broken/corroded wire?
Post by mattlon on Mar 24, 2021 21:50:53 GMT 1
checked everything obvious, not sure it is the coil as the spark comes back. any common faults i'm missing? after others experiences and advice?
Post by dougw on Apr 8, 2021 22:31:02 GMT 1
The riveted connection on the trigger coil by the flywheel can cause problems, I'm thinking back to 1986 now , but I seem to remember mine came loose and caused a misfire on mine.
