Gee
Post by Gee on Mar 21, 2021 21:55:24 GMT 1
I've got an import RD350lc with steering lock on the headstock with no key. Lock appears to be undamaged, is there any way of getting a key for it from Yamaha with the frame number, v5 etc? Also I've seen that Yambits do a replacement lock assembly, would it be possible to get the old one out without damaging the housing so a new one would go in? Thanks Gee
Post by 29davyt on Mar 21, 2021 22:08:50 GMT 1
Gee
Post by Gee on Mar 21, 2021 22:27:42 GMT 1
Thanks Davy, just ordered one from Germany Gee
Post by jackjabba on Mar 22, 2021 8:33:48 GMT 1
I've got an import RD350lc with steering lock on the headstock with no key. Lock appears to be undamaged, is there any way of getting a key for it from Yamaha with the frame number, v5 etc? Also I've seen that Yambits do a replacement lock assembly, would it be possible to get the old one out without damaging the housing so a new one would go in? Thanks Gee I drilled my old one out, but the front end was off so cleaning the swarf out of the headstock was easy.
Gee
Post by Gee on Mar 22, 2021 19:36:06 GMT 1
Thanks Jack, I'll give it a go and see how it goes ๐
Post by stusco on Mar 22, 2021 19:55:17 GMT 1
I screwed a self tapper into mine and used my bearing puller slide hammer to yank it out
Gee
Post by Gee on Mar 22, 2021 20:21:18 GMT 1
I screwed a self tapper into mine and used my bearing puller slide hammer to yank it out Cheers mate, I did wonder if that might be an option, I'll wait till it comes then see how I'm going to tackle it ๐
ajh
Post by ajh on Mar 22, 2021 23:08:55 GMT 1
Drilling is easy and swarf not a problem if you drill at the 1oโclock position to hit the roll pin or just below the bit that sticks up so it breaks off. Either way the lock will come out without the drill going right through and any swarf getting past back of lock
Gee
Post by Gee on Mar 23, 2021 20:18:36 GMT 1
Drilling is easy and swarf not a problem if you drill at the 1oโclock position to hit the roll pin or just below the bit that sticks up so it breaks off. Either way the lock will come out without the drill going right through and any swarf getting past back of lock Thanks for that๐ I'll have a look at the new one when it comes ๐
Gee
Post by Gee on Mar 25, 2021 0:03:55 GMT 1
Credit where its due. I ordered the steering lock in the eBay link on 21st and it was delivered today the 24th from Germany. Amazing service ๐
