Post by mattlon on Mar 14, 2021 12:48:27 GMT 1
Hi We have adjusted the floats to 21mm but have a leak on the left hand card, does the fuel level now sit higher than the gasket? What's the best solution? Many thanks Matt
Post by elsiefan on Mar 14, 2021 14:07:23 GMT 1
Hi Matt and welcome.
If the float height is 21mm from the gasket face to the top of the float, then that is correct, I can't comment on where the fuel sits inside the bowl. You might want to check the needle valve under the float, mine was dirty and leaked fuel from the overflow pipe, gave it a clean up and all seems well now. Another alternative is a punctured float.
ajh
Post by ajh on Mar 14, 2021 17:15:06 GMT 1
Hi We have adjusted the floats to 21mm but have a leak on the left hand card, does the fuel level now sit higher than the gasket? What's the best solution? Many thanks Matt sometimes a dry gasket may take a little time to seal, i think they sort of swell to seal Also you can screw and m4 nozzle into the drain plug and attach a plastic tube and hold it up alongside the float chamber, turn the fuel on to see the actual level in the tube
Post by mattlon on Mar 16, 2021 15:41:26 GMT 1
Made a big difference
Post by mattlon on Mar 16, 2021 15:44:56 GMT 1
Checked with a tube and the fuel was below gasket height
Post by 4l04ever on Mar 16, 2021 19:32:14 GMT 1
If the leak is not resolved, can you identify where the leak is coming from?
