Post by sidney81 on Jan 28, 2023 20:22:47 GMT 1
Post by andy748 on Jan 28, 2023 20:32:26 GMT 1
Looking great Chris, yer Bro's gotta be pleased with that. Andy.
Post by sidney81 on Jan 28, 2023 21:29:58 GMT 1
Looking great Chris, yer Bro's gotta be pleased with that. Andy. thanks !! Yes he's excited π
Post by donkeychomp on Jan 28, 2023 22:26:01 GMT 1
Love that engine casing, and the red anodised bits suit it to a T!
Post by Yogi on Jan 28, 2023 22:56:17 GMT 1
Only thing I see wrong pipe wise is the 2t pipe between the pump and reservoir should go on the inside of the engine mount plate with the 3bolts through and over the top of the rear of engine
You did ask π
Matt π»
Post by sidney81 on Jan 28, 2023 23:43:51 GMT 1
Only thing I see wrong pipe wise is the 2t pipe between the pump and reservoir should go on the inside of the engine mount plate with the 3bolts through and over the top of the rear of engine You did ask π Matt π» thanks Matt π yes I did,some things your just not sure on especially the route of pipes cables etc.thank you π
Post by sidney81 on Jan 28, 2023 23:44:18 GMT 1
Love that engine casing, and the red anodised bits suit it to a T! Alex thanks Alex ,he loves it
Post by steeley on Jan 29, 2023 5:57:56 GMT 1
Nice .
Post by dusty350 on Jan 29, 2023 9:13:52 GMT 1
Looks awesome Chris
Post by masonmart on Jan 31, 2023 3:12:46 GMT 1
Superb work Chris and great that you have the machines, the skills to use them well and a great knowledge of the bikes. I'm just starting my rebuild but I'm unfortunately not blessed with any of these characteristics.
Post by sidney81 on Jan 31, 2023 11:10:58 GMT 1
Superb work Chris and great that you have the machines, the skills to use them well and a great knowledge of the bikes. I'm just starting my rebuild but I'm unfortunately not blessed with any of these characteristics. hi thank you for the nice comment,, good luck with your build be nice to see it ? And I must say I've seen loads of beautiful builds from guys who don't have the engineering background and they turn out fantastic bikes ππ
Post by zig on Jan 31, 2023 11:45:42 GMT 1
looks fantastic and all the details are there , still following so keep us up to date
ZiG
Post by sidney81 on Jan 31, 2023 13:29:05 GMT 1
looks fantastic and all the details are there , still following so keep us up to date ZiG thanks zig π
Post by sidney81 on Feb 11, 2023 13:36:21 GMT 1
Well the pressure test revealed we had a leaky base gasket π‘, so this morning we stripped it out ,added a smear of threebond built it back up ,re tested and now found we have a small porous hole in the barrel,FFS π so stripped it off again,now I'm looking at running a small weld over the hole to seal it up . Thought I'd share as normally ( posts) are all good and how things are going well so makes a change to have a bugger it post ! Oh well sure ill sort it for him π
Post by slyfox762 on Feb 11, 2023 13:50:20 GMT 1
Seems to be a common place to leak there on a lot of different bikes. How are you going to seal it?
Post by sidney81 on Feb 11, 2023 13:54:20 GMT 1
Seems to be a common place to leak there on a lot of different bikes. How are you going to seal it? hi ,I'm going to weld over the hole fingers crossed it should sort it
Post by lcmarky on Feb 11, 2023 15:20:08 GMT 1
What brake discs do you have?
Post by lcmarky on Feb 11, 2023 15:24:15 GMT 1
Seems to be a common place to leak there on a lot of different bikes. How are you going to seal it? hi ,I'm going to weld over the hole fingers crossed it should sort it I guess if you open it up a bit too then dress it back once youβre happy itβs sealed. I put my barrels and head into the blast cabinet and used some Sealey shot blasting grit which gave them a lovely finish ready for paint.
Post by sidney81 on Feb 11, 2023 15:55:37 GMT 1
What brake discs do you have? I think there ebc I can check, my brother brought them π
Post by donkeychomp on Feb 11, 2023 22:49:22 GMT 1
Well that blows. Literally. But I'm sure you can sort it out Chris.
Post by Tobyjugs on Feb 12, 2023 16:49:43 GMT 1
A long time ago i helped a work colleague seal an area of an engine block that was porous. Basicaly you spread loctite on the area and then pressurize (low pressure) it. The loctite goes into the pores and seals it. Do you want me to inform about which loctite was used and the method?
Post by midlifecrisisrd on Feb 12, 2023 16:53:25 GMT 1
I had that thought too but thought instead of pressuring the engine you would create a vacuum and it would suck it in
Post by sidney81 on Feb 12, 2023 19:45:55 GMT 1
A long time ago i helped a work colleague seal an area of an engine block that was porous. Basicaly you spread loctite on the area and then pressurize (low pressure) it. The loctite goes into the pores and seals it. Do you want me to inform about which loctite was used and the method? thank you ,I will try welding it first , that might be plan B !! I'll keep you posted
Post by JonW on Feb 12, 2023 23:12:01 GMT 1
Chris, looking at the pics closely, might it be a small crack? I wonder if the cylinder was dropped on that corner at some point in its life?
Post by sidney81 on Feb 13, 2023 11:04:44 GMT 1
Chris, looking at the pics closely, might it be a small crack? I wonder if the cylinder was dropped on that corner at some point in its life? hi , well spotted but it's not a crack looks like it ha ha it's what I first thought,it's that tiny hole it's leaking from π£
Post by JonW on Feb 13, 2023 12:41:31 GMT 1
no worries, just pointing it out in case you hadnt seen it.
Post by sidney81 on Feb 13, 2023 14:14:11 GMT 1
no worries, just pointing it out in case you hadnt seen it. I was showing a guy at work this morning and he goes it's cracked π€£π€£ looks like it but it's a mark in the cast, one thing is for sure it's got a bloody hole π€£
Post by abar121 on Feb 13, 2023 19:25:38 GMT 1
Great to discover the leaks at this stage, where it all can be fixed without tears!
Post by sidney81 on Feb 13, 2023 21:38:34 GMT 1
Post by JonW on Feb 13, 2023 23:06:54 GMT 1
Good work Chris, Looks like a good, strong repair.
