Post by sidney81 on May 7, 2022 14:19:30 GMT 1
Oil pump back from arrow looking fantastic ,big thanks to him for sorting it out for us ππ
Post by sidney81 on May 21, 2022 20:36:22 GMT 1
Hi ,I also picked up brother's pv frame for the powder coating ,it's lovely to see it nice and shiny, hopefully we can now move forward with this build. π€
Post by donkeychomp on May 21, 2022 22:11:04 GMT 1
Swish!
Post by JonW on May 23, 2022 3:21:55 GMT 1
Oil pump back from arrow looking fantastic ,big thanks to him for sorting it out for us ππ What would we do without him!?
Post by donkeychomp on May 23, 2022 22:18:15 GMT 1
Erm. Be forced to use premix? His work is world class it really is.
Post by sidney81 on May 26, 2022 20:35:31 GMT 1
Post by donkeychomp on May 26, 2022 21:13:17 GMT 1
Gotta love Brembos!
Post by lcmarky on May 27, 2022 16:21:34 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid.
Interesting isn't it how we approach things.
Ordered some material today to make a bottom yoke - no TIG you see!!
Post by lcmarky on May 27, 2022 16:22:39 GMT 1
Have you got a blast cabinet? Glass bead media would have all those ally surface the same.
Post by Tobyjugs on May 27, 2022 16:44:52 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid. Interesting isn't it how we approach things. Ordered some material today to make a bottom yoke - no TIG you see!! Yes it is, i made a plate very similar to this. The piece that Sidney welded in i made from two collars which pressed into the plate. I made it like that so i could adjust the amount the plate could move in or out on the wheel axle.
Post by lcmarky on May 27, 2022 17:09:17 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid. Interesting isn't it how we approach things. Ordered some material today to make a bottom yoke - no TIG you see!! Yes it is, i made a plate very similar to this. The piece that Sidney welded in i made from two collars which pressed into the plate. I made it like that so i could adjust the amount the plate could move in or out on the wheel axle. ..a floater? Is there not an ideal position for the alignment centrally?
Post by sidney81 on May 27, 2022 19:44:28 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid. Interesting isn't it how we approach things. Ordered some material today to make a bottom yoke - no TIG you see!! yes it is ! I do what I'm good at ,I'm not a machinist alough I can get buy πbut welding/ fabrication is my trade / job so I suppose that's why I choose to do it that way,even if it may not be the best way π
Post by Tobyjugs on May 27, 2022 20:38:45 GMT 1
Yes it is, i made a plate very similar to this. The piece that Sidney welded in i made from two collars which pressed into the plate. I made it like that so i could adjust the amount the plate could move in or out on the wheel axle. ..a floater? Is there not an ideal position for the alignment centrally? No just two halfs that press into the hole of the plate from each side. It makes it easy to remove the two spacers and change the dimensions and move the plate in towards the center of the rim or out towards the swing arm.
Post by Tobyjugs on May 27, 2022 20:40:00 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid. Interesting isn't it how we approach things. Ordered some material today to make a bottom yoke - no TIG you see!! yes it is ! I do what I'm good at ,I'm not a machinist alough I can get buy πbut welding/ fabrication is my trade / job so I suppose that's why I choose to do it that way,even if it may not be the best way π Thats the best way, the way you feel comfortable with.
Post by lcmarky on May 28, 2022 9:01:45 GMT 1
Because my TIG welding skill is developing let's say, I'd have machined that from solid. Interesting isn't it how we approach things. Ordered some material today to make a bottom yoke - no TIG you see!! yes it is ! I do what I'm good at ,I'm not a machinist alough I can get buy πbut welding/ fabrication is my trade / job so I suppose that's why I choose to do it that way,even if it may not be the best way π I'm the exact opposite - could do with you as a neighbour!!
Post by sidney81 on May 31, 2022 21:36:14 GMT 1
Post by Tobyjugs on May 31, 2022 22:18:03 GMT 1
Hi Sidney theres no doubt about your skills, they are fantastic and normally i would keep my opinion to my self but as this is to do with brakes i will comment here.
I think the pin on the swing arm is a bad idea. This is due to the small contact area and being round sitting in a slot. Both parts are made from a relatively soft material subjected to substantial force whilst braking. I don't think it will take to long before you start to get excessive clearance between the two parts. If you make the pin into a rectangle you will have a lot more contact area to help spread/absorb the braking forces making the components last a lot longer.
I hope your not offended by my comments Tony
Post by sidney81 on May 31, 2022 22:47:36 GMT 1
Hi Sidney theres no doubt about your skills, they are fantastic and normally i would keep my opinion to my self but as this is to do with brakes i will comment here. I think the pin on the swing arm is a bad idea. This is due to the small contact area and being round sitting in a slot. Both parts are made from a relatively soft material subjected to substantial force whilst braking. I don't think it will take to long before you start to get excessive clearance between the two parts. If you make the pin into a rectangle you will have a lot more contact area to help spread/absorb the braking forces making the components last a lot longer. I hope your not offended by my comments Tony hi I'm not a skilled bike builder at all Tony I certainly don't see myself in that way but thank you ,and offended not at all !! Thank you I take your advice on board and will certainly look into it ππChris
Post by Tobyjugs on May 31, 2022 22:55:07 GMT 1
Hi Sidney theres no doubt about your skills, they are fantastic and normally i would keep my opinion to my self but as this is to do with brakes i will comment here. I think the pin on the swing arm is a bad idea. This is due to the small contact area and being round sitting in a slot. Both parts are made from a relatively soft material subjected to substantial force whilst braking. I don't think it will take to long before you start to get excessive clearance between the two parts. If you make the pin into a rectangle you will have a lot more contact area to help spread/absorb the braking forces making the components last a lot longer. I hope your not offended by my comments Tony hi I'm not a skilled bike builder at all Tony I certainly don't see myself in that way but thank you ,and offended not at all !! Thank you I take your advice on board and will certainly look into it ππChris Nor am I. I have lots of people that can help me and give me advice. You are still very skilled being able to construct and use machinery. Most people can do one or the other.
Post by sidney81 on Jul 3, 2022 7:40:02 GMT 1
Post by JonW on Jul 3, 2022 14:26:03 GMT 1
Nice! Great result!
Post by abar121 on Jul 3, 2022 14:36:56 GMT 1
Looking good!
Post by yamark on Jul 3, 2022 19:03:31 GMT 1
Superb Chris, great work
Post by sidney81 on Aug 7, 2022 21:46:03 GMT 1
Post by donkeychomp on Aug 7, 2022 22:36:27 GMT 1
The pup doesn't look impressed but I am. Great work mate and always nice to see them back on their own two booties!
Post by dusty350 on Aug 8, 2022 6:41:34 GMT 1
That's some turnaround already mate - great work Dusty
Post by sidney81 on Aug 8, 2022 6:58:24 GMT 1
The pup doesn't look impressed but I am. Great work mate and always nice to see them back on their own two booties! Alex she wasn't,she was waiting to go to the beach ποΈπ
Post by sidney81 on Aug 8, 2022 6:58:55 GMT 1
That's some turnaround already mate - great work Dusty thanks dusty ,he's getting on with it now ππ
Post by abar121 on Aug 9, 2022 9:32:19 GMT 1
That looks wonderful. Love the way it sits too.
Post by sidney81 on Aug 14, 2022 16:07:44 GMT 1
