Post by Athers on Mar 7, 2021 10:55:25 GMT 1
Hi all
Quick question how much latteral left to right play should there be on the drive sproket when mounted and tightened with the lock ring and both 10mm bolts.
Thanks in advance
Post by brigitte on Mar 9, 2021 21:58:09 GMT 1
Hello,
I don't like this solution. Its only acceptable on a smaller bike. When you replace the sprocket with a new one and the washer too and it's still wobbling, you know you gear shaft is worn out. At least you need no big tools to change the sprocket. The only advice I can give you is to check the lock ring for wear.
Brigitte
