Post by mellow on Mar 1, 2021 12:26:06 GMT 1
Morning All. I need to do a fork seal. The manual states it should have 10W/30 SE Engine oil. Does anyone know what the equivalent viscosity is in fork oil weight? Thanks.
dc
Post by dc on Mar 1, 2021 14:37:53 GMT 1
I think most old bike manuals suggest oils in that format. SE doesn't exist anymore having moved on. You could look at dedicated fork oils in the 10w or 15w range, there are others and some go as far as mixing them for 12.5w etc. The 15w will be a little firmer than the 10w so I think it depends on what kind of ride you prefer. Motul offer 10w at medium and 15w at medium heavy. I used the 15w in my X7 last and find it perfect. My manual suggested 10/20 but after a chat with Opie, I settled on the 15w. They said fork oils are not that easy to compare against those older style figures but 10w and 15w are a good starting point. I think a few on here use the 10w from what I remember seeing. www.opieoils.co.uk/c-777-motorcycle-fork-oil.aspx
Post by mellow on Mar 1, 2021 15:23:17 GMT 1
ok thank you. i'll go for the 10w as its for my dt
dc
Post by dc on Mar 1, 2021 15:25:52 GMT 1
ok thank you. i'll go for the 10w as its for my dt Sounds good.
Post by bare on Mar 2, 2021 19:34:13 GMT 1
Mobil 1 Synth ATF... Not a typo. Don't laugh, just try it. You will be hard pressed to source a more capable Fork oil
Post by mellow on Mar 4, 2021 16:43:59 GMT 1
thank you
Post by elsiefan on Mar 12, 2021 15:52:21 GMT 1
Mobil 1 Synth ATF... Not a typo. Don't laugh, just try it. You will be hard pressed to source a more capable Fork oil Definitely not a typo....I used to use ATF fluid in my forks back in the day, before there was such a thing as dedicated fork oil. Worked a charm and I could also top up the auto box on my old Audi 200 with it as well 👍
Post by beardy on Mar 12, 2021 16:42:01 GMT 1
Me too and have been for years. Every time I change a front tyre I replace the fork oil too.
