Post by zig on Feb 23, 2021 22:55:10 GMT 1
plenty of post's on the forum here but i have not seen the same problem as i have....
new build , engine fitted but not going as yet
brand new F2 loom
brand new banshee coils
brand new stator
brand new Motobatt
everything plugs in as it should with the loom bar left hand side switchgear which i am waiting on in the post...
switch on the ignition and the PV Servo does the sweeps , all good , until i started to switch the light switch on the throttle right hand side switchgear to an on/of position and suddenly the PV
motor starts to make some movement and noise , totally baffled and first thought it is a faulty PV motor , is there a way to test them at all ??
any help appreciated
ZiG
Post by stusco on Feb 24, 2021 8:50:27 GMT 1
The right hand switch gear has the kill switch maybe that has something to do with the problem
Post by midlifecrisisrd on Feb 24, 2021 10:45:49 GMT 1
Sounds daft but check the fuse connections are perfect
I've had issues when you switch on the lights and the extra load causes a big voltage dip or the dodgy connection can't handle the power
Post by zig on Feb 24, 2021 14:46:18 GMT 1
The right hand switch gear has the kill switch maybe that has something to do with the problem the sound it makes is almost like it is trying to do a sweep but is almost restricted by something , when i look closely at the servo when operating the switchgear i can clearly see a small amount of movement along with the sounds it's making....really need a working servo from a running bike to plug in and maybe rule it out ?? ZiG
Post by zig on Feb 24, 2021 14:49:51 GMT 1
Sounds daft but check the fuse connections are perfect I've had issues when you switch on the lights and the extra load causes a big voltage dip or the dodgy connection can't handle the power Steve Thanks Steve...certainly have a try , it's really unusual the sound's coming from it along with what i have described to 'Stusco' above , lie it is trying to do a sweep but is almost restricted by something ?? ZiG
Post by midlifecrisisrd on Feb 24, 2021 15:00:17 GMT 1
It's not uncommon for them to twitch or grumble a bit
Post by shaunthe2nd on Feb 24, 2021 16:21:39 GMT 1
It's not uncommon for them to twitch or grumble a bit Steve Women?
Post by midlifecrisisrd on Feb 24, 2021 16:52:35 GMT 1
It's not uncommon for them to twitch or grumble a bit Steve Women? I'd have said most likely in that case 😆 Steve
Post by JonW on Feb 25, 2021 0:35:24 GMT 1
The right hand switch gear has the kill switch maybe that has something to do with the problem the sound it makes is almost like it is trying to do a sweep but is almost restricted by something , when i look closely at the servo when operating the switchgear i can clearly see a small amount of movement along with the sounds it's making....really need a working servo from a running bike to plug in and maybe rule it out ?? ZiG How tightly have you setup the cables? Ive found if they cant quite reach the ends then they will do the 'twitch and grumble', sometimes the cables need slackening off just a tad.
Post by zig on Feb 25, 2021 10:14:49 GMT 1
the sound it makes is almost like it is trying to do a sweep but is almost restricted by something , when i look closely at the servo when operating the switchgear i can clearly see a small amount of movement along with the sounds it's making....really need a working servo from a running bike to plug in and maybe rule it out ?? ZiG How tightly have you setup the cables? Ive found if they cant quite reach the ends then they will do the 'twitch and grumble', sometimes the cables need slackening off just a tad. yes for sure i will check the set-up / cable tension , any help considered , really baffling , and really suppose i won't see or know for sure if there is a problem until i get the bike up and running jus seems strange it makes the motion and noise only when the light switch is turned on/off ZiG
Post by JonW on Feb 25, 2021 13:07:07 GMT 1
not saying its the fix for your problem but any chattering was fixed by slacking for me And... well starting the bike will fix it... you wont hear the chattering when its running
Post by zig on Feb 25, 2021 22:18:49 GMT 1
not saying its the fix for your problem but any chattering was fixed by slacking for me And... well starting the bike will fix it... you wont hear the chattering when its running o.k so i set-up the PV cables again from scratch everything lining up etc.....connected the battery and a lot lot smoother plus a lot less 'chatter' from the servo and as you say jonw , when i get the motor running i wont hear any remaining 'chatter' cant thank you all enough that chipped in , i couldn't have got it sorted without you all BIG THANKS ZiG
