mk1rob
Post by mk1rob on Dec 1, 2009 16:37:34 GMT 1
first of all i am new to this forum and like to say hi to everyone and i look forward to using this forum and getting t know you lot rob. what id like to know is are the forks off of a Mk2 rd125 a different thickness than the Mk1? thanks rob
Post by carlos on Dec 1, 2009 17:37:31 GMT 1
Welcome mate! The mk one forks are a different size to the mk2 ones I think the mk 1 stanshions are 30mm diameter and the mk2 are 33mm
mk1rob
Post by mk1rob on Dec 1, 2009 18:03:01 GMT 1
thank you Carlos I've just bought my bike as a resto project and think its got the Mk2 front end. or its just a Mk2 and the bloke just lied to me is there away of finding out what Mk it is? like frame and engine numbers
Post by carlos on Dec 1, 2009 18:36:08 GMT 1
How old is the bike? You can tell from the first 3 letters of the frame/engine number! If I'm wrong can someone correct me! MK1 - 10W MK2 - 2HK There are some other differences too, mk2 had a smaller front wheel, a different caliper, a different front mudgaurd, different clocks (all the same as the very first TZR125) If it's sill got the original engine in the engine and frame number should be the same, if this is the case the mk 1 clutch cover had what is described as an old telephone style (ie 12 little circles around the wors Yamaha, whereas the MK2 didn't - www.carls-rd125lc.co.uk/gallery20.html - that's a mk 2 one Also, the Mk2 had clip on handle bars, whereas the Mk1 had one bar bolted on to the yolk! You may have a bike built up from bits which could have mk1/2 parts! Put some pics up!
mk1rob
Post by mk1rob on Dec 1, 2009 18:51:15 GMT 1
yeah my frame has got 10w stamped on it its 1985 b reg and the engine has the 12 circles in it so i am guessing that hes changed the front end at sum point because it has the clip on handle bars forks and yokes.which is a shame really because i wanted to make it all standard and original that's just made it a bit harder for me to do thanks again
Post by carlos on Dec 1, 2009 19:44:54 GMT 1
You're looking at finding handle bars, forks and yolks to put it back to standard!
I may be wrong but it may handle different with mk 2 forks on, is the front wheel smaller than the rear?
mk1rob
Post by mk1rob on Dec 2, 2009 11:45:30 GMT 1
its got the standard Mk1 wheels on it still when i striped it all down it looks like he has had spacers made up to take the Mk1 wheel with the Mk2 forks. if i got hold of a top yoke off of a Mk1 would i be able to modify them to take the Mk2 forks have them bored out or would that make them to week?
mk1rob
Post by mk1rob on Dec 2, 2009 16:01:59 GMT 1
hi robbo sorry to hear about your accident. i there's a set on eBay now item num 180439182395 there at £5 atm with£ 15 delivery but its got 4 people watching unless some one on here has a set i am after a set of Mk1s if anyone has any?
