Post by joshready on Feb 17, 2021 22:35:02 GMT 1
Does anybody get it done on there gears? My 125 drivetrain spins amazing free. Im guessing itll do similar on the 4lo box.
Post by JonW on Feb 17, 2021 23:54:57 GMT 1
Interesting. Never heard of it, fill us in and let us know what its benefits are and the costs.
Post by reedpete on Feb 18, 2021 0:52:18 GMT 1
Post by JonW on Feb 18, 2021 2:08:58 GMT 1
I'm not sure id call the gearboxes in our bikes 'high end performance boxes' but hey if it helps then why not?
Post by joshready on Feb 18, 2021 2:45:20 GMT 1
I'm not sure id call the gearboxes in our bikes 'high end performance boxes' but hey if it helps then why not? On my cr125 the rear wheel spins free like the front. Im guessing it would make a better difference on a roadtrack bike and a larger gearbox. I only did my cogs too, so was fairly cheap.
Post by 4l04ever on Feb 18, 2021 10:15:51 GMT 1
Post by st66 on Feb 18, 2021 18:27:33 GMT 1
Unless your Raceing its massive overkill to do this but its personal preference a high quality gear oil would suffice so unless you plan to thrash it every second,, a cr will benefit yes but a cr twostroke revs to over ten grand in a heartbeat allot more strain also on the box, a standard lc won't,, but its your choice as I say
Post by liffy16 on Feb 18, 2021 19:44:50 GMT 1
Running a non o ring chain has the same effect, back in the day my old R6 race bike made 2bhp more from standard chain to 520 non o ring chain
Post by wallcraft on Feb 19, 2021 20:37:10 GMT 1
Could be worth a punt if it makes troublesome neutral selection better?
Post by bare on Feb 20, 2021 18:44:59 GMT 1
?? My pore old Iua unit albeit With Shift star mod, oem Yama Springs, Plates, using large Ferodo .. 'racing' :-) frictions, and a bit of minor fettling. Shifts faster, quicker, lighter than the G box on MY 600RR.. True.. it's a constant source of amazement. This despite various 'claimed' Honda factory tricks, such as undercut dogs, micro polishings. ALL intended to make shiftings lighter and quicker. Setup your bike up 'capably' and most of all: Don't Fix What Ain't Broke
ps Troublesome Neutral selection was fully Solved on MY g'box by using GL4 oil.
