Post by kevleeds1964 on Jan 30, 2021 15:39:30 GMT 1
Hi just wondering if you can help I have a ypvs when I turn ignition on there are no lights on clocks only headlight and rear light working nothing else even Rev counter not working battery fully charged and the four fuses all look good any help appreciated regards Kev « Prev1Next »
Post by marrcel on Jan 30, 2021 18:20:20 GMT 1
Fuse
Post by midlifecrisisrd on Jan 30, 2021 18:43:48 GMT 1
Check the clock plugs are in the correct place. The wire colours each side should match
As the clock lights AND the tacho don't work it suggests more than 1 circuit not working hence me thinking The plugs are wrong
Post by Shytalk on Jan 30, 2021 19:29:07 GMT 1
The fuse connections are prone to loosen now they’re older so even if the fuses are ok if there’s not enough spring tension holding them in that can cause voltage drops.
