Headstock
Jan 27, 2021 14:30:08 GMT 1
via mobile
Post by yorkieboy on Jan 27, 2021 14:30:08 GMT 1
Can anyone help? I'm fitting 05/06 zxr636 forks into my 4l0 frame. Is it possible to get bearings to suit the headstock and the stem of the zx or do I need to get tha zx stem skimmed to fit the frame,as the lc one wont fit the zx bottom yoke. TIA
Post by andy748 on Jan 27, 2021 16:31:44 GMT 1
Hello mate, the 636 yokes go directly onto an RGV250, so with a 5mm spacer from Norbo onder the taper bearing they should go straight on? Andy.
Post by midlifecrisisrd on Jan 27, 2021 17:35:31 GMT 1
But does the rgv not use a larger OD bottom bearing
There may not be enough space for a bearing between the ID and OD
Post by jon on Jan 27, 2021 17:40:27 GMT 1
I think between the two above it answers the OP question.
Yes with a spacer and LC bearings?
Headstock
Jan 29, 2021 12:51:09 GMT 1
via mobile
Post by yorkie on Jan 29, 2021 12:51:09 GMT 1
Hello mate, the 636 yokes go directly onto an RGV250, so with a 5mm spacer from Norbo onder the taper bearing they should go straight on? Andy. Thanks for your reply buddy the LC headstock is 48mm and the zx stem is 35mm but try as I can,cant find no bearings of that diameter to fit
Post by andy748 on Jan 29, 2021 19:14:39 GMT 1
It's the 2003 yoke that fits with the LC taper bearings not the later models as the yoke changed dimensions. Andy.
Headstock
Jan 30, 2021 17:30:28 GMT 1
via mobile
Post by yorkieboy on Jan 30, 2021 17:30:28 GMT 1
It's the 2003 yoke that fits with the LC taper bearings not the later models as the yoke changed dimensions. Andy. ... Andy is that a 03 zx yoke that fits a rgv
