Post by veg on Jan 19, 2021 8:42:53 GMT 1
Noticed these are becoming more sought after. Alan how difficult would these be too make or are they too large to be printed?
Post by bare on Jan 19, 2021 18:40:35 GMT 1
Should be an easy 3d print. It can be divided into parts and glued together. Ultimate Size is not an issue. Need a scan of one though.. to base a print file on.
Post by alankelly on Jan 19, 2021 20:44:12 GMT 1
Noticed these are becoming more sought after. Alan how difficult would these be too make or are they too large to be printed? Hi Veg How big is it length and width as I don’t have one to hand Can anybody do a very quick measure please Thanks Al
Post by alankelly on Jan 19, 2021 20:45:46 GMT 1
I do the air box frame  But it is a squeeze
Post by veg on Jan 19, 2021 22:56:05 GMT 1
Hi al I don’t have one to hand, it’s not for me it was I’d noticed a few wanted ads for them and I know they’re getting more difficult to locate and or expensive and I thought I know someone whose a little bit of an expert at these things 👍😁
Post by reedpete on Jan 20, 2021 13:37:52 GMT 1
Don’t forget the snorkel would also be required ..even if the lid shell can be printed. whole air-boxes are still ‘reasonable’ ..in relative terms..
On my list , the Coil cover/loom tidy is the next to get done but will probably need a support structure printed and then removed in post print tidying.
Post by veg on Jan 20, 2021 13:49:18 GMT 1
Completely forgotten about the snorkel Pete as I’m not standard guess that make it more difficult. Yes coil headstock cover would be another. I only mentioned it as I’d seen a few posts asking for them.
Post by bare on Jan 20, 2021 23:27:52 GMT 1
Don't understand any trepidations. The snorkel is a dead simple print. likely a 2 hour one. Even a Komplete Airbox assembly (I certainly would IF I was in need ) can be readily printed (once scanned) even using Petg if wanting Life of the Bike durability. Currently printing a FW ta152H 1:12 scale RC airplane (https://3dlabprint.com/shop/focke-wulf-ta152h/ ) If curious. A Yamaha airbox would be Very Simple by comparison. Depends entirely on what is familiar /comfortable doing I suppose.
Post by beardy on Jan 21, 2021 12:37:00 GMT 1
Good read up on the fw152. Glad there’s still one about to restore.
Post by shaunthe2nd on Jan 21, 2021 13:03:14 GMT 1
The LC snorkel is made of rubber, presumably to make it flexible for fitting/removing. Even then it can be a bit of a fight. It will need a bit of redesign if its going to be made from rigid plastic.
Post by bare on Jan 22, 2021 18:56:35 GMT 1
The LC snorkel is made of rubber, presumably to make it flexible for fitting/removing. Even then it can be a bit of a fight. It will need a bit of redesign if its going to be made from rigid plastic. Erm.. One CAN print in Flexible rubber facsimile material.. rather easily :-)
Post by shaunthe2nd on Jan 22, 2021 19:55:15 GMT 1
Every day is a school day.
