Post by tsa on Jan 8, 2021 15:57:13 GMT 1
Hi All. Does anyone have access to or know someone with a mandrel tube bender as I need some tube bending without creasing or shrinkage?
Post by 4l04ever on Jan 8, 2021 20:51:08 GMT 1
Post by muttsnuts on Jan 8, 2021 20:53:21 GMT 1
Hi All. Does anyone have access to or know someone with a mandrel tube bender as I need some tube bending without creasing or shrinkage? what diameter Kenny, I have some, but limited on sizes and what material and is the tubing seamed or seamless ?
Post by tsa on Jan 8, 2021 21:29:49 GMT 1
Rob that's not man enough mate.
Dave 1" x 1.5mm seamed stainless bent to 45 degrees on a 150mm radius
Post by muttsnuts on Jan 8, 2021 22:00:40 GMT 1
um, ok 1.5mm thick, that's pretty tough, I'll see what I have, think I've got a 25mm mandrel, not sure on the formers radius though, so will check, might have to be gently heated to help bend it, would that cause a problem ?
Post by midlifecrisisrd on Jan 8, 2021 22:04:58 GMT 1
25mm is a standard electrical conduit size
If stuck try tool hire places for a conduit bender
Remember my trade test doing a bubble in 25mm hard drawn steel conduit
If they bend that then 1.5 wall stainless should be fine
Post by steve h on Jan 8, 2021 22:27:18 GMT 1
Done lots of 25mm stainless conduit tube bends in std conduit bender.
Post by midlifecrisisrd on Jan 8, 2021 22:37:52 GMT 1
Done lots of 25mm stainless conduit tube bends in std conduit bender. Oh no, it's 2 Steve the sparkies 😀 Steve
Post by tsa on Jan 9, 2021 14:14:50 GMT 1
um, ok 1.5mm thick, that's pretty tough, I'll see what I have, think I've got a 25mm mandrel, not sure on the formers radius though, so will check, might have to be gently heated to help bend it, would that cause a problem ? Dave that wouldn't an issue as it can be cleaned with a scotchbrite. I have someone trying the bend this week so hang fire unless you want to see for yourself if you can do it.
Post by steve63 on Jan 10, 2021 22:52:08 GMT 1
Rob that's not man enough mate. Dave 1" x 1.5mm seamed stainless bent to 45 degrees on a 150mm radius Maybe try Aalco in Hull and see if they have anything off the shelf? Probably not exactly what you want, maybe 1"x18g and 125mm radius and in 304 but worth a look?
