Post by dvd172 on Oct 31, 2020 10:07:37 GMT 1
Hi all, just reaching out to see if anyone can help with a spacer question on rear wheel of 350lc. I've been putting the wheel bearings in, and I'm sure the internal spacer is too short. Does anyone know or has one they can measure? The one I have is 63mm, and I think it should be 65mm? Thanks
jay
2 stroke or not 2 stroke
Post by jay on Oct 31, 2020 22:14:59 GMT 1
Had the same problem with mine only was missing the internal spacer yes its 61 mm long and there is another spacer with a 4mm collar that goes inside the wheel bearing to meet the internal spacer to make up the 65mm between the 2 wheel bearings 👍 hope this helps Regards Jay
