Post by 84rzrider on Oct 19, 2020 5:09:17 GMT 1
Post by pdxjim on Oct 19, 2020 6:22:34 GMT 1
Looking good, Tim.
Post by donkeychomp on Oct 19, 2020 21:47:12 GMT 1
I really enjoyed that. The engine noises between both bikes were fantastic to hear. Alex ps what is the speed limit in Virginia?
Post by 84rzrider on Oct 19, 2020 23:01:39 GMT 1
Thanks!!
Post by spanky1 on Oct 20, 2020 0:31:35 GMT 1
Great video.
I really like the Gauges - is that a Koso? Do they take a lot of modification to install on an RZ/YPVS?
I have an electronic tach on my '85 - but not sure how the actual speedo would work as I assume it's not cable driven.
Post by 84rzrider on Oct 20, 2020 5:20:12 GMT 1
www.rzrd500.com/phpBB3/viewtopic.php?f=3&t=12490&start=15Spanky my install starts on page 2 of memory serves of that post with pictures. It isn't a bad job to install it. I had a spare parts gauge cluster so cut the cannon plugs off of it so none of the factory harness is altered making it easily reversible. It is a Koso RX2 GP. Well worth the money. I put it on because I got tired of the squealing tach and speedometer and the frequent disassembly required to lube them.
Post by 84rzrider on Oct 20, 2020 5:25:12 GMT 1
The speedometer uses a magnetic pick up that mounts to the caliper hold down bolt with a supplied bracket and some magnets that stick into your rotor mount bolts. You also have to buy thier temp sensor for the water temperature inficator. I love it. It works perfect.
Post by spanky1 on Oct 20, 2020 11:54:14 GMT 1
Thanks for sharing 84rzrider - it looks great on the bike and the install looks really clean.
Post by 84rzrider on Dec 12, 2020 18:59:24 GMT 1
Thanks!
