Post by 2old2goslow on Oct 6, 2020 21:23:13 GMT 1
Been working through my recent purchase of a 350 hybrid to get ready for it's MOT. Whilst adjusting the handlebars / controls... The right hand switchgear came apart in my hands... It appears one of its previous owners had an issue with the treaded part and did a poor temporary repair.. glued the bolt into place with only 180 deg of thread in the body. So, my question... Can anyone ID which model this is off... And anyone got a spare for sale... And the cut-off switch isn't working either. I'll add a pic it's not an original LC part... Might be from a YPVS LC2 hope this works
Post by 4l04ever on Oct 6, 2020 22:23:10 GMT 1
Looks like YPVS, but not sure which model. Could you helicoil the damaged thread?
Post by 2old2goslow on Oct 6, 2020 22:39:22 GMT 1
its snapped off the casing where the thread goes... its for the bin looking at it... it felt a little "loose" on te bars already then one turn of the bolt and the thing fell to bits....
Post by shaunthe2nd on Oct 6, 2020 22:53:17 GMT 1
Looks similar to what I bought for my 1983 31K LC2. All black apart from a little bit of red when you flick the engine cut switch.
Post by 2old2goslow on Oct 6, 2020 23:06:01 GMT 1
Think you're right.. it has a 31k engine so presume lots of bits salvaged from the donor bike... cant find one on Norbo's site..and Yambits site isnt easy to navigate / find.
Post by JonW on Oct 7, 2020 3:52:48 GMT 1
31K... early 83/4 have different cabling to the F1. Unsure about the N models.
Post by Deleted on Oct 7, 2020 6:57:07 GMT 1
The back halves of the 31K switchgear I'm sure are the same
I had a similar problem with a dodgy thread with my F1 and used a 31K back half
All I did was remove the innards of the lower case and put them into another, it's fairly simple to do
Post by 2old2goslow on Oct 7, 2020 8:32:05 GMT 1
Thanks for the input guys... I will continue my quest to find a replacement.
Post by midlifecrisisrd on Oct 7, 2020 8:43:41 GMT 1
Yep as said it's a 31k ypvs
EBay is your friend but expect to have to paint it and apply new decals
Post by chrisg on Oct 7, 2020 10:40:54 GMT 1
Is it still available from Fowlers? Probably not cheap ☹️
Post by Shytalk on Oct 7, 2020 14:51:53 GMT 1
Thanks for the input guys... I will continue my quest to find a replacement. It's an LC2 switch gear, I probably have a spare, I know that I have a pair - not sure about an individual, won't be able to check until Friday.
Post by 2old2goslow on Oct 7, 2020 16:02:21 GMT 1
Thanks for the input guys... I will continue my quest to find a replacement. It's an LC2 switch gear, I probably have a spare, I know that I have a pair - not sure about an individual, won't be able to check until Friday. Let me know what you find in the treasure trove.... and how much you want for it the pair. thanks Ian.
Post by Shytalk on Oct 9, 2020 15:30:41 GMT 1
I had a quick look earlier today, I do have a very good pair of switch gear controls, not been able to look too much as I've had to go out to work - I'll only be selling them as a pair though, PM me if you're still interested.
