Post by chud786 on Oct 5, 2020 23:46:13 GMT 1
Can't find a Tourmax one specific for F2 are there any compatible ones? or any other recommendations Cheers
Post by JonW on Oct 6, 2020 0:14:08 GMT 1
OEM is cheap enough Ive found for Master cyls. In fact a brand new 3HE version of the master is good value on Partzilla etc.
Post by chud786 on Oct 6, 2020 21:47:50 GMT 1
OEM is cheap enough Ive found for Master cyls. In fact a brand new 3HE version of the master is good value on Partzilla etc. Thanks jonw I have seen cheap ones on Ebay but when it comes to brakes I don't want to skimp on quality so if there is no alternative I'll go for OEM. I'll check Partzilla. Cheers
Post by JonW on Oct 6, 2020 23:12:13 GMT 1
OEM is cheap enough Ive found for Master cyls. In fact a brand new 3HE version of the master is good value on Partzilla etc. Thanks jonw I have seen cheap ones on Ebay but when it comes to brakes I don't want to skimp on quality so if there is no alternative I'll go for OEM. I'll check Partzilla. Cheers Thats all OEM, 3HE is just the later version of the coffin shaped master cylinder.
Post by nokturnal on Oct 8, 2020 16:45:44 GMT 1
careful the bore isn't worn. i replaced mine with OEM kit only to have it leak.
