Post by midlifecrisisrd on Sept 17, 2020 19:28:14 GMT 1
As title, I ain't got a clue
How do you tell the difference between early and late LC brake calipers?
Post by veg on Sept 17, 2020 19:33:28 GMT 1
By looking for the differences. 👍 You’ve not been charged for this advice. You’re welcome.
Post by oldelsieboy on Sept 17, 2020 19:35:12 GMT 1
As title, I ain't got a clue How do you tell the difference between early and late LC brake calipers? Steve OEB
Post by veg on Sept 17, 2020 19:37:57 GMT 1
Like I said look at the differences 👍
Post by midlifecrisisrd on Sept 17, 2020 19:52:34 GMT 1
By looking for the differences. 👍 You’ve not been charged for this advice. You’re welcome. Tw4t 🙄 If I had both types I'd be able to do that Still wouldn't know which is which so thank you OEB Steve
Post by tony2stroke on Sept 17, 2020 20:23:37 GMT 1
As title, I ain't got a clue How do you tell the difference between early and late LC brake calipers? Steve OEB Don't know if you have sussed it yet or not, if you look at left caliper (nerwer one) you can see the groove goes past the bracket part, on the older 1 it goes it doesn't go so far, then there is the O part on the side of caliper, the early ones have a slightly larger O that goes closer to the edge, the newer caliper has a slightly smaller O and is further in giving a larger area after the O, then there is the bracket that holds to the forks, newer ones have an extra part that the disc goes through, the older type don't have that extra bit, the newer type is wider than the older type too, hope that makes sense to you.
Post by flames on Sept 17, 2020 20:57:09 GMT 1
Looking at the pics, am I right in thinking older had a spring fitted between halves and newer didn't? I thought it was the other way round.
Post by tony2stroke on Sept 17, 2020 22:36:16 GMT 1
Looking at the pics, am I right in thinking older had a spring fitted between halves and newer didn't? That's right.
