Post by flames on Aug 30, 2020 16:28:57 GMT 1
I am in the process of looking for early ypvs rear wheel, (the sort with 2 holes in the spokes ) I am in no rush as i will need to sell my lc wheels etc to fund what i need, so i am just trying to work out what it is all going to cost me or more to the point locating the parts at a reasonable price. Unfortunately they always seem to be sold separately so need to make sure i am looking for compatible parts. Sooo are the sprocket carriers for early and later power valves the same or interchangeable? Also , the cush rubbers seem to be available, are these the same for early and later wheels? Unfortunately I have a lot of other stuff to locate and fund so i have to be a bit strategic in how much i spend hence why i am hoping to be able to mix and match to achieve the best prices i can. Have I ever mentioned i am a tight ar5e???
Post by Yogi on Aug 30, 2020 16:32:38 GMT 1
All the parts are interchangeable The only real difference is the rear wheels on n1/f1 have longer spindles due to the box section swingarm
Post by midlifecrisisrd on Aug 30, 2020 16:36:20 GMT 1
I'll have a look in my shed mate, think I have a 31k rear wheel, may even have a carrier
Post by flames on Aug 30, 2020 16:37:55 GMT 1
All the parts are interchangeable The only real difference is the rear wheels on n1/f1 have longer spindles due to the box section swingarm Thanks Yogi, that's good news as it will not narrow my search.
Post by andy748 on Aug 30, 2020 17:59:37 GMT 1
Hi Flames, i have a carrier in the garage if you need one? Andy.
Post by flames on Aug 30, 2020 18:17:59 GMT 1
I'll have a look in my shed mate, think I have a 31k rear wheel, may even have a carrier Steve Nice one thank you. let me know if you have any joy. Can you also let me know how much you want with postage if you are willing to part with it. I was a bit hasty and bought a carrier off e bay for £25 posted as it seemed cheap compared to some on there.
Post by flames on Aug 30, 2020 18:22:39 GMT 1
Thanks mate, but unfortunately i was a little hasty after Yogi's reply and bought a carrier off the bay .Missed midlife's post as well. Hopefully he has a wheel i can buy to fit my hub too.
Post by Yogi on Aug 30, 2020 18:49:26 GMT 1
I’ve got spare wheels if your stuck mate
Post by flames on Aug 30, 2020 19:25:13 GMT 1
I’ve got spare wheels if your stuck mate Nice one thank you. I only need rear though. I have fitted xj 600 front end with fz top yoke and clip ons. I may be after a rear caliper and/or carrier if you have 1? I have an fzr600 caliper etc but don't know if it fits the pv carrier. I haven't measured the mounting points yet.
Post by midlifecrisisrd on Aug 30, 2020 19:29:01 GMT 1
I'll have a look in my shed mate, think I have a 31k rear wheel, may even have a carrier Steve Nice one thank you. let me know if you have any joy. Can you also let me know how much you want with postage if you are willing to part with it. I was a bit hasty and bought a carrier off e bay for £25 posted as it seemed cheap compared to some on there. Sorry mate, just been out and had a look I knew I had 4 wheels and thought it was a pair of each but turns out I have 2 pairs of f2 wheels ☹ Steve
Post by flames on Aug 30, 2020 19:33:08 GMT 1
Nice one thank you. let me know if you have any joy. Can you also let me know how much you want with postage if you are willing to part with it. I was a bit hasty and bought a carrier off e bay for £25 posted as it seemed cheap compared to some on there. Sorry mate, just been out and had a look I knew I had 4 wheels and thought it was a pair of each but turns out I have 2 pairs of f2 wheels ☹ Steve No problem mate. Thanks for looking.
Post by flames on Aug 30, 2020 19:38:07 GMT 1
I’ve got spare wheels if your stuck mate If you have a rear you would be prepared to part with could you let me know a price with postage please. I understand if you only have pairs and don't want to split them. Cheers
Post by Yogi on Aug 30, 2020 20:15:54 GMT 1
I’ll check what ones I’ve got,are you powdercoating them
Post by flames on Aug 30, 2020 20:22:57 GMT 1
I’ll check what ones I’ve got,are you powdercoating them Haven't yet decided whether to powder coat or paint TBH. I have made my mind up on colour ....several times.... They will either be red, white or black. I have also decided whether i am going to do the whole wheel or only the parts that are painted as standard........( they will be one or the other ).
Post by Yogi on Aug 30, 2020 20:32:24 GMT 1
The reason I asked was because I’ve got a rear that was blasted then painted as normal but the unpainted parts are not as smooth as they should be
Perfect for powder coating but would need polishing if not painted
Post by flames on Aug 30, 2020 20:45:37 GMT 1
The reason I asked was because I’ve got a rear that was blasted then painted as normal but the unpainted parts are not as smooth as they should be Perfect for powder coating but would need polishing if not painted My front has good ally and i do like the look of them with the ally showing. However i have seen them fully painted/ coated and also like the look of them. I can smooth the ally if needs be.
Post by Yogi on Aug 30, 2020 20:54:48 GMT 1
I’ll dig it out in the week mate and show you 👍
ahthud
Post by ahthud on Sept 2, 2020 7:51:51 GMT 1
Ive got a rear caliper and carrier up for grabs if you still need one 👍
Post by flames on Sept 2, 2020 10:29:29 GMT 1
Ive got a rear caliper and carrier up for grabs if you still need one 👍 Cheers mate, will let you know once I have the wheel sorted.
