Post by flames on Aug 22, 2020 20:34:28 GMT 1
Hi all
I have later 4lo barrels and allspeed exhausts. I have always used the fibre type washers but never really been happy with them. Just wandering what others have used. Have seen the copper type but not sure if these are ok with the allspeeds?
Post by chrisg on Aug 23, 2020 10:29:17 GMT 1
One note of caution, be wary of overtightening the exhaust studs. They are now getting on a bit and itโs common for the ally to give up. I know from experience ๐
Post by stusco on Aug 23, 2020 10:44:11 GMT 1
I use the copper ones from norbo never had a leak
Post by flames on Aug 23, 2020 10:46:53 GMT 1
Cheers mate haven't thought about that.
Always seems a faf to get the fibre ones to crush evenly which usually ends up with one side or other over tightened to compensate.
Post by flames on Aug 23, 2020 10:48:18 GMT 1
I use the copper ones from norbo never had a leak Cheers, fink I will give them a go then. Was hoping I could but weren't sure if they only worked on standard pipes.
Post by stusco on Aug 23, 2020 11:07:56 GMT 1
Im sure they will be fine mine are on tsa ,and standard,are allspeeds different?
Post by 4l04ever on Aug 23, 2020 13:39:18 GMT 1
You can seal them in with Flu Sealant from Screwfix. Leave to go off overnight once all bolted up.
Post by flames on Aug 23, 2020 15:44:38 GMT 1
Im sure they will be fine mine are on tsa ,and standard,are allspeeds different? I don't know mate. Mine came with allspeeds so have never had standard. I thought standard look like they are shaped where they join the barrel whereas the sleeve for allspeeds is flat.
Post by flames on Aug 23, 2020 15:48:56 GMT 1
You can seal them in with Flu Sealant from Screwfix. Leave to go off overnight once all bolted up. I used sealant where the pipes slide into / over the adaptor part that bolts to barrel when I built it last time. When I took engine out this time I can see the adaptor parts aren't sitting square even tho I spent time trying to get them so last time. Am thinking the fibre type washers maybe don't squash squarely.
