Post by mak595 on Aug 19, 2020 15:59:31 GMT 1
please bare with me as electrics make my brain hurt..making a start on wiring up the ignitech unit I'm i right in thinking the red,brown and green from the stator are not used with the ignitech unit?
Post by midlifecrisisrd on Aug 19, 2020 16:17:26 GMT 1
Correct
Make up a small loom with bullet connectors with one wire looping between them then off to a ring terminal to go onto a frame bolt to ground them out and stop any damage to the windings
Post by mak595 on Aug 19, 2020 16:54:46 GMT 1
Correct Make up a small loom with bullet connectors with one wire looping between them then off to a ring terminal to go onto a frame bolt to ground them out and stop any damage to the windings Steve Thanks steve
Post by mak595 on Aug 19, 2020 17:49:21 GMT 1
Ok hopefully ive got the PV servo wired up and the coils so next question, is this plug used? Goes to the cdi normally. Think I just need the switched live and the kill switch to figure out. Where's the best spot for the switched live (brown) ? The bikes a 31k btw Cheers
Post by mak595 on Aug 19, 2020 17:53:42 GMT 1
Also I assume the 2 plugs to the redundant PV controller are now useless, could I connect the iggy switched live straight to the brown on this plug ?
Post by midlifecrisisrd on Aug 19, 2020 18:25:49 GMT 1
Also I assume the 2 plugs to the redundant PV controller are now useless, could I connect the iggy switched live straight to the brown on this plug ? Yes that brown and black are best used as the power supply The black yellow at both plugs is the old pv signal/ypvs elec tacho Steve
Post by midlifecrisisrd on Aug 19, 2020 18:27:06 GMT 1
Ok hopefully ive got the PV servo wired up and the coils so next question, is this plug used? Goes to the cdi normally. Think I just need the switched live and the kill switch to figure out. Where's the best spot for the switched live (brown) ? The bikes a 31k btw Cheers The kill switch is the black/white wire on that 4 way plug š Steve
Post by mak595 on Aug 19, 2020 18:45:03 GMT 1
Thanks Steve, your a š
Post by midlifecrisisrd on Aug 19, 2020 19:27:56 GMT 1
Your welcome š
I'm going to fit mine where the pv controller fits I think as the power and servo plug are there, the stator wires are close as well
I'll run all the spare wires all taped up towards the tail and heat shrink the end
Post by mak595 on Aug 19, 2020 19:53:47 GMT 1
I've run the servo wires straight to the servo unit, that will be ok, I assume? Ignore the reg plug, got a new one to fit š
Post by midlifecrisisrd on Aug 19, 2020 20:01:22 GMT 1
Electrically that is better as there is one less set of connection
I'm just OCD and don't like spare unused connections left š¤£
Post by LC_BOTT on Aug 19, 2020 20:21:26 GMT 1
Isn't the kill switch wired differently to normal on the Iggy?, thought it had to be 12V in to the selected input?? (rather than down to ground) interested as just doing mine
Post by roblc350 on Aug 19, 2020 21:50:16 GMT 1
Iām also about to start mine This would all be of help but Iām going into a F2 loom so all different plugs & coloured wires to mine
Post by midlifecrisisrd on Aug 20, 2020 11:03:38 GMT 1
Isn't the kill switch wired differently to normal on the Iggy?, thought it had to be 12V in to the selected input?? (rather than down to ground) interested as just doing mine On the one I did I'm sure it was just a wire to connect to the kill switch so connected to earth to kill Steve
Post by midlifecrisisrd on Aug 20, 2020 11:04:19 GMT 1
Iām also about to start mine This would all be of help but Iām going into a F2 loom so all different plugs & coloured wires to mine Colours are the same š Steve
Post by roblc350 on Aug 20, 2020 12:39:51 GMT 1
Cheers Steve Hope you can help me further Reading back some are the same colours,some not as far as i can see for instance coming from the stator ( 31k )there is a curved top 4 pin plug with 3 white wires & 1 black wire ? also coming up there is the 3 wire plug ( connect all 3 up & ground as not req ) Correct ? there is a single black fly lead with a bullet connector ? then a 2 pin plug red / white green / white ?
Post by midlifecrisisrd on Aug 20, 2020 13:54:46 GMT 1
Cheers Steve Hope you can help me further Reading back some are the same colours,some not as far as i can see for instance coming from the stator ( 31k )there is a curved top 4 pin plug with 3 white wires & 1 black wire ? The 3 white are the generator wires. These plug into the bike loom, not the Iggy. The black as you call it should actually be a blue. It's the neutral switch also coming up there is the 3 wire plug ( connect all 3 up & ground as not req ) Correct ? Yes, they are the hi and lo speed windings there is a single black fly lead with a bullet connector ? Yes, that's the engine earth wire. It also connects to the loom then a 2 pin plug red / white green / white ? They are the pick up wires Hope that helps Steve
Post by roblc350 on Aug 20, 2020 14:18:59 GMT 1
Yes it does Cheers Mate
Post by mak595 on Aug 22, 2020 13:25:39 GMT 1
Hopefully the unit is wired in now, still need to fit clutch cover so I can kick it over and see if ive got a spark but PV servo cycles when ignition is on so good start !
